Question about Mtd Garden
I have a 22 inch mtd snowblower and the drive transmission wont work
  • yadayada
    yadayada Dec 04, 2016
    Hi don stanley, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
4 Suggested Answers
SOURCE: Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Posted on Dec 26, 2008
SOURCE: need manual for a mtd snowblower, 22
For a manual go to mtd.com You will need the model number to find the correct one. As for you problem take the fuel line of where it hooks to the carb see if you have fuel getting to the carb. If you do you will need to remove and clean the carb. Before you remove the whole carb take the bolt out that holds the carb bowl on and clean it this might do to trick.
Sam
Posted on Jan 08, 2010
rycgl
  • 1545 Answers
SOURCE: how much oil goes in
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
Posted on May 01, 2011
The auger wont disengage on a mtD 8 HP 26 INCH SNOWBLOWER THE HANDLE STAYS DOWN
follow the cable to the auger either snapped or came loose
Dec 22, 2016 | Mtd Garden
5.5 22 inch yard machine mtd snowblower wont stay running
If it starts but dies in short time you may have a failing coil. Check for spart when it shuts off. If you still have spark you probably need carb service to fix a sticky float.
Dec 26, 2012 | Garden
Hose hook up for carburetor mtd 3/21 snowblower
one goes into the side of the carb. next to the engine, one goes into the air cleaner
Oct 16, 2012 | Mtd 22" Yard Machine Push Mower
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
How do I know if installed the v-belt properly for an MTD 22" self-propelled mower #12b-264c062. The belt has been installed around the engine and transmission pulleys and behind the belt keeper. does...
You need to check the owners manual. And be sure you have the correct belt.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Jul 31, 2009 | Arnold Corporation Arnold/MTD 22" Lawn...
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
MTD 5/24 Model 317E610E382 won't start
if u get a can of starting fluid and u get it to run for a lil bit that will help getting the fuel moving and will start easier next time
Mar 01, 2009 | Mtd 22" Yard Machine Push Mower
Broken off shear bolt stuck in snowblower
hit the pin out with a punch and a hammer after drilling off any part of the pin that might be impeding your progress. you might also have to put some juice into your swings because a nail is too soft
Jan 11, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
83 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
