Question about Kyocera Office Equipment & Supplies
How do you clean a Kyocera fs-1118 mfp drum - Kyocera Office Equipment & Supplies
    Genius:
  • 1,056 Answers
You don't, you replace them.
They are extremely delicate and react poorly to any thing touching them.
Posted on Dec 03, 2016
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
xptareq2000
  • 1447 Answers
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Posted on Aug 27, 2009
anantakumarj
  • 330 Answers
SOURCE: Kyocera fs-1118 When I want to use scanner
are you able to take print ........... and have you installed the paper cut software for scan the document ..... please check while you connecting printer to your pc its detecting or what ...... please check above thing .... please post your comment if you facing same problem ...............
Posted on Jan 13, 2010
Testimonial: "Yes i can print. But only for scan i got message cannot...I search site kyocera and install printer driver and TWAIN driver.USB cable replaced"
  • 165 Answers
SOURCE: error code c6400 on fs-1118
fuser temperature over /under u need service engineer to reset it
Posted on Nov 04, 2010
ath10
SOURCE: Kyocera Mita Kyocera FS-1028 MFP Laser Print -
printer is working but scanner is not working
Posted on Jan 21, 2012
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
Mar 11, 2017 | Kyocera FS-1028MFP Mono Multifunction...
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
Mar 17, 2012 | Kyocera FS-1118MFP Laser Printer
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
Mar 10, 2012 | Kyocera Copystar CS-1820 Black and White...
Error code c6400 on fs-1118 mfp
Oct 26, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Jan 23, 2009 | Kyocera FS-1118 Printer
I have a FS-1118 MFP Kyocera printer it has refused to print and the error message is that the waste toner is full how can i empty the waste toner?
Jan 21, 2009 | Kyocera FS-1118MFP Laser Printer
54 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
