Question about Brother Office Equipment & Supplies
Brother printer beeps intermittently
Driver is updated and it has toner
  • Brother Master
  • 1,915 Answers
Is it the printer beeping or do you have the printer connected to a UPS and the UPS is beeping? I have run into this with users all the time who do not realize you cannot plug a printer into a UPS.
Posted on Dec 03, 2016
Brother MFC-8460N All-In-One Printer Beeps 15 time every hour
Please see the control panel display (any error code or problem issue)
Dec 16, 2017 | Brother MFC-8460N All-In-One Printer
Brother Printer 2150N, toner is on and toner is Ok, but printer not working
Don't waste your time.
Uninstall printer prog, reinstall latest update from brother website.
Apr 10, 2011 | Brother HL-2150N Laser Printer
How do I access and change out toner cartridge (brother-HL2140?
To get the exact detailed instructions for how to replace the brother HL-2140 toner cartridge.Please click the link below and follow the instructions:---- http://technoanswers.blogspot.com/2011/02/how-to-change-toner-cartridge-on.html ------------- Keep updated.Thanks.Helpmech.
Feb 25, 2011 | Brother Office Equipment & Supplies
Tried to print using my MFC-685CW. Was told that my ink cartridge was empty. Put in a new cartridge (LC51BK). Was told that the cartridge container was now empty. What to do?
STEP 1: Verify the firmware version of your Brother machine:
a. Press the OK key 2 times.
b. Press the UP ARROW (+) key 5 times.
c. Press the OK key 2 times.
The firmware version will be displayed on the LCD.
- If the firmware version is 1.01 or 1.02, go to STEP 2: Update the firmware of your Brother machine.
- If the firmware version is 1.08 or above, go to STEP 4: Toner usage and yields.
STEP 2: Update the firmware of your Brother machine:
A firmware update tool is available that will allow you to update your Brother machine with the most recent version firmware by downloading updates over the Internet. The updated firmware will assist in optimizing toner usage.
The Brother printer driver must be installed and working properly prior to the update of the Brother machine. The firmware update tool also requires that you have Java installed on your computer. The firmware update tool will not work if Java is not installed. If you do not have Java installed or are not sure if it is installed on your computer, you may download Java from http://www.java.com.
To update the firmware, follow the instructions listed below:
DO NOT interrupt the process or turn off the machine once the update has begun. Doing so may corrupt the memory on the machine and may require the machine to be serviced in order to correct the issue.
1. Open an Internet web browser and go to http://welcome.solutions.brother.com
2. Select your country and language.
3. Type in the model of your machine or select it from the appropriate section (Ex: HL3070CW in the Color Printer section).
4. Select Downloads.
5. Select your OS and language for step 1 and 2 on the web site. Click the Search button.
6. The Firmware Update Tool will be listed at the bottom of the web page. Click Information & Download.
7. Click the Download button and I Accept if you accept the license agreement.
8. A dialog box appears with options for Run, Save, or Cancel. Select Run. You may also download the firmware update tool for later use by selecting Save.
Nov 01, 2010 | Brother MFC-685cw InkJet Printer
BROTHER HL-2040 PRINTER WON'T PRINT
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.
Apr 19, 2009 | Brother HL-2040 Laser Printer
Brother HL 2070n
Check the website of brother. If they allow you to download and update its firmware. Update the firmware and driver as well.
Mar 24, 2008 | Brother HL-2070N Laser Printer
Drum light blinks, drum and toner have been replaced
you need to update your machine after every time that you repleacing toner or drum
contact tech support of brother company or i can help you but it will cost you
elvis
Jan 02, 2008 | Brother HL-5240 Laser Printer
PROBLEM BROTHER 2040 PRINTER
Have you replaced the drum and toner? It sounds as if the printer is saying it's time. The motor constantly running usually means it's trying to add toner to satisfy the toner sensor, but it's empty.
May 29, 2007 | Brother HL-2040 Laser Printer
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
