Question about RCA Televison & Video
My tv won't come on.
It's done this before and eventually came back on but I think something definitely needs fixed now! Its an 52" RCA HD LED LCD Full HDTV. We hit the power button, and the standby light goes off....but the screen doesn't come on. Model #LED52B45RQ
  • 2920 Answers
SOURCE: Flashing green power light on TV
have the power supply checked out sounds like it went out
Posted on Aug 26, 2008
  • 373 Answers
SOURCE: Tv shuts off
can you go into the menu and rest it
Posted on Feb 10, 2009
SOURCE: power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Posted on Feb 23, 2009
  • 8617 Answers
SOURCE: Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Posted on Mar 13, 2009
  • 541 Answers
SOURCE: Model 52
These units are famous for bad capacitors in the power supply. When the capacitors go it causes voltages to fluctuate out of range. You have to remove the deflection PCB to repair this. Also look for loose connections at the high voltage transformer. This can be a dangerous circuit to work on. Have a repair shop check it out for you. Thanks
Posted on Oct 29, 2009
I have a 52" 1080p 120 Hz LCD HD Samsung TV that
You have a problem on your Power supply board, possibly a bad capacitor or loose connection. You can look hard at your power board and check for these things or replace it from places like or etc
Jan 19, 2011 | Samsung LN-T4671F 46 in. LCD Television
Pixel solarization around letters and faces. 52" LED Sony I've tried adjusting the contrast, back light, and all other adjustments.
there is some interference with all flat tvs and it would be interesting to know is this in hd or standard def? in standard def the tv has to upscale the picture to fit a 52" screen and you will get this effect. there is nothing you can do, however this should dissapear in high definition.
Nov 28, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My RCA 52" HD tv will turn on with sound but no picture
You need a new projection bulb.Not so easy to do it your self but it can be done with good dexterity.
Sep 03, 2010 | RCA HD52W58 52" TV
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
RCA D52130 52 in. Won't Display High Def
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Powers on and then right back off
Try and clean the two filters on the tv this should be the first thing to do.
Feb 01, 2008 | RCA HD52W58 52" TV
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Televison & Video Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
