Question about Pool & Spa
The hot tub high speed jets will not work, the controller is a Balboa Water Group FWV300AV, any suggestions?
    Top Expert:
  • Pool & Spa Master
  • 7,206 Answers
Possible bad 2 speed relay
Posted on Nov 12, 2017
  • 990 Answers
SOURCE: Motor is hooked up correctly according to
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
Posted on Oct 31, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Intermittent jet problem on Spa form hot tub
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
Coastsider
  • 331 Answers
SOURCE: We have a Great Lakes spa with a Balboa control
Contact Balboa's Customer support department directly at 800-645-3201, follow the prompts to customer tech support (or press 0 and ask for customer support). You will need to be at the spa, control panel open and ready to read off the chip number, and you will need to be proficient with a test meter (AC voltage). The SN error is related to a bad sensor(s), but can also indicate a failed board. An incorrect sensor set will also create this problem, so confirm you used the exact or compatible replacement. If the SN code issue is no longer a problem, but the spa is still not heating, look and see if the heater led is on. If it is, you likely have some burned relays on the board, which can be replaced cheaper than replacing the board. If you need more help, email me at info@coastsideservices.com
Posted on Aug 30, 2010
SOURCE: I have a Balboa vs
It sounds like you have the possibility of a couple of things going wrong here. It could easily be a board issue based upon what you are saying. However, it could also be a pump issue because you are having limited success with filing the tub up half way. The best suggestion is to have a spa technician come out to assist you in determining what exactly is going wrong here.
You really have not provided enough details on the problem to help you diagnose exactly what is going on here.
Posted on Sep 21, 2011
My pump will only work on speed 2, however ...it will only heat up on speed 1, so the hot tub is cold. Any idea??
Spas that are connected with the supply voltage of 120, will only heat on low speed.It is designed that way, so that when the motor switches to high-speed, heater will turn off, so that the current draw will not overload a common 15 a outlet.
by the description of your question, I would venture a guess, that the relay for low-speed, located on the circuitboard, has failed.
if I was the technician on site, doing a troubleshoot, I would want to know if the motor it's self is operational, on both speeds?
So I would bring in an alternate source of power, and test each speed individually, confirming whether or not low-speed actually does work?If it does not, then you know it is the low-speed side of the pump motor that has failed. But if low speed does work with alternate power, then you know it is in the controlling circuit.
Tech Support for Balboa Water Group
1-714-384-0384
Jun 08, 2015 | Pool & Spa
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Balboa 52502 val 5m7
have you cleaned your filter recently. Sound like there may be a low flow error in low speed
either that or the start capacitor on your pump is bad and the pump will not come on in low speed unless you first give it a boost in high speed
anytime you ask for heat with insufficient flow there will be an error message
Jun 21, 2012 | Balboa Instruments Pool & Spa
Hot tub keeps running all night keeping me awake. How do you shut it off? It's a Great Lakes.
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
Sep 18, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
103 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
