Question about Building Materials
No learn button on my Lynx455 purhased 1997/98 as required in tutorial for sabaru 2017 outback to sync built in door opener. how do I resolve?
3 Suggested Answers
  • 740 Answers
SOURCE: over heating
Check water pump or bad radiator there is a circulation problem. As a last resort check and make sure its not a bad head-gasket check oil for antifreeze look under oil filer cap for cream-ish white residue. Good Luck
Posted on Dec 19, 2008
  • 3197 Answers
SOURCE: I have a new (new
Try going to this website. Click on Program and then follow the directions.
Posted on Apr 12, 2011
I bought a 2017 Lexus RX350.I have a lift master garage door opener with a red button. I can not get it to work. I had a 2010 Lexus RX350 and it worked great.Can you help me.
If you are following the instructions to the letter for the car to learn the opener code then take it back for warranty.
Feb 22, 2017 | Building Materials
Why won't Chamberlain 1040-6 garage door opener open or close?
In addition to the ANT suggestion, are you able to open/close the door with the button first? And then check the 12-volt battery in the remote control.
Work-around: Modern cars have the ability to learn the motor's code. Then I use the built-in openers on my cars to open the garage door as work-around. All you have to do is initiate the learning process by pressing a button on the motor, and then keep pressing your built-in opener's button until the light becomes steady. Try to let your car stay as close to the motor as possible.
Apr 27, 2014 | liftmaster Chamberlain Garage Door Opener...
Trying to sync 2002 volvo s60 garage door opener with garage
Hold any of the buttons down while you press the door opener remote and wait for alight in the dash to flash that the code has been learned by the car. You may also google "HOMELINK" programming for more info.
Aug 28, 2012 | 2002 Volvo S60
Where to find a leran button in sears 139.655000 model garage door opener.Plase show me photos.
No photo necessary. There is no learn button on that opener. It was built before learn buttons were even dreamed of.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have the Liftmaster Chamberlain Professional Formula I model 102.1499A and for some reason, the learn button will not sync with the homelink on two of my cars. Is there a way to reset the learn button? ...
Here is the information I have for homelink.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster professional formula 1 and am trying to get the opener to sync with my car. is there a roaming setting on the unit that needs to be worked with in order to have it sync with my...
You have to first have your cars Homelink system learn your current remote (follow owners manual) THEN have the garage door opener learn the cars Homelink (push openers learn button then press the Homelink button you previously had learn your remote. Two learning steps required because the LiftMaster is a 'rolling code system'
Aug 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Will the remotes for the 139.53684 automatically
no the remotes should automatically re sync with the PS3 when you put the remote on charge.
Apr 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Over heating
Dec 19, 2008 | 2000 Subaru Outback
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
How do you program...
The built-in system in your '98 Jeep is made by a company called "HomeLink", a subsidiary of Johnson Controls Inc. The website,, has a walk through tutorial that should do the trick. It's a matter of taking and existing hand-held remote control for your opener, pressing and holding its button, and pressing and holding the button you wish to use in the visor at the same time (with the remote positioned very close to the visor). The appropriate flashes on the LED above the row of three buttons will let you know when the HomeLink system is set up. Depending on you opener, you may then need to locate a "learn" button on the overhead garage door opener mechanism, and program the HomeLink system into the opener's memory.
Jun 19, 2008 | 2004 Ford Thunderbird
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
