247.5x119x87mm is what in inches? - Office Equipment & Supplies
    Top Expert:
  • Office Equip... Master
  • 76,848 Answers
10.846457"X4.68504"X3.4252"
Posted on Dec 04, 2016
  • 601 Answers
An inch, ironically enough, is defined as 2.54cm. There are 10 mm is a cm, so 1" = 25.4mm.
Good luck,
Paul
Posted on Dec 06, 2016
Convert 6.490'' into inches
with a double quote ( " ) after the 6.49 it is already inches? Roughly six and a half inches.
Conversion of inch to centimeter (cm)
www.calculconversion.com/conversion-inch-cm.html
Convert or calculate inch to cm or cm to inch. Free online converter of inches and centimeters (cm).
Millimeters to Inches conversion ' mm to inches - Metric Conversion
www.metric-conversions.org > ... > Length Converter > Millimeters Conversion Bookmark Page inches to mm (Swap Units) Millimeters to Inches table - Click here for table options. ... The millimetre is a unit of length in the metric system, equivalent to one thousandth of a metre (the SI base unit of length).
convert 6 490 into inches Google Search
Mar 19, 2017 | Office Equipment & Supplies
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
How to calculate cubic feet?
Multiply 21 inches by 14 inches by 10 inches to get 2940 cubic inches. There are 12 inches in a foot, so there are 12^3=1728 cubic inches in a cubic foot. Divide 2940 cubic inches by 1728 cubic inches per cubic foot to get about 1.7 cubic feet.
Alternatively, first convert all measurements to feet. 21 inches is 1 3/4 feet, 14 inches is 1 1/6 feet, 10 inches is 5/6 feet. Multiply them together to get 245/144 cubic feet, which again is about 1.7 cubic feet.
It's always nice when doing a problem two different ways gives the same answer.
Jul 04, 2014 | Office Equipment & Supplies
What is the dimension of rectangular prism with volume of 40 cubic inches
There are an infinite number of solutions.
It could be one inch by one inch by 40 inches, two inches by one inch by 20 inches, two inches by two inches by ten inches, four inches by one inch by ten inches, four inches by two inches by five inches, etc.
Any three positive numbers which multiply together to 40 will be a solution.
May 22, 2014 | Office Equipment & Supplies
How many inches in a cubic inch
Inch is a unit of length. Cubic inch is a unit of volume.
One cubic inch is one inch by one inch by one inch, or two inches by one inch by one-half inch, or three inches by one inch by one-third inch, etc.
May 11, 2014 | Refrigerators
What is size of freezer that is 64" tall X 33" wide x 24" deep?
64 inches times 33 inches times 24 inches is 50688 cubic inches.
One foot is 12 inches, so one cubic foot is 12 inches times 12 inches times 12 inches or 1728 cubic inches.
50688 cubic inches divided by 1728 cubic inches per cubic foot is about 29.3 cubic feet.
Apr 25, 2014 | Office Equipment & Supplies
E2020 answer keys
a. radius is 7 inches and circumference is 43.96 inches.
Apr 03, 2014 | Office Equipment & Supplies
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
SUM 5/16 INCH 7/8 INCH
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Nov 17, 2009 | Bosch 85414M 7/8 Inch Diameter 5/16 Inch...
43 people viewed this question
jasbo
jasbo
