Question about Samsung Heating & Cooling
Samsung air source heatpump communication error A1 20 and E101 how can I correct this?
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101
Explanation and Checking points = Indoor unit communication error - checkwiring
Posted on Oct 27, 2011
E101
Out door "fan" can be replaced with any of same size but if u need to replace the unit then its all too tech and its tech details needs to be as same as the one that was installed. Outdoor unit doesnt only have a fan fir cooling but alongwith it condensor, compressor etc etc
Apr 14, 2014 | Samsung AS18A6RB Air Conditioner
I have a carrier air handler heatpump can I use a Rudd heatpump condensor
Yes if they match up correctly. I would stay away from Ruud though. Best off with Carrier or Trane in my opinion. Also, if your spending the money to replace the condenser, you should spend the extra bit and replace the air handler as well. New systems use a new refrigerant that is more cost effective and better for the environment.
Jan 26, 2014 | Heating & Cooling
E101
Room sensor problem. Replace in indoor unit
Nov 15, 2013 | Heating & Cooling
EROR E101
Room temp sensor defective. Try to reset by unplug and plug it with an intervel of 10 seconds. If it not clicked replace new sensor.
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Phase 2 to 3
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Washing Machines
ErrorCode = 101
Oct 18, 2011 | Samsung AS18A6RB Air Conditioner
I have a Select Comfort 2000 thermostat. I just replaced new batteries couple days ago. The past week my heat will be working fine all day and/or night then suddenly it will not kick in and the aux light...
Sounds like you have a heatpump. Is that correct? When it gets under 35F or so the heatpump just isn't able to keep up with the heat demand and will require help from a backup source such as electric strip heaters. The way the thermostat works is that the heatpump will work until room temperature gets 2F to 4F below what you have the thermostat set for, the Auxillary heat will kick in to help out. I think I am answering your question, please let me know if I have misread your problem and I'll try to come up with something else.
Dec 05, 2010 | Heating & Cooling
Error C4 or CA
Turn off the heatpump. Start it again when temperature gets hotter than -20c.... Error C4 or CA (overheated compressor) often strikes after C2 error (and this error you often get when temp is belov -25c)
I had the same error myself, temperature was below -27. I turned the heatpump OFF. Turned it on again when temp was at -8c. No errors in display, and runs great! :-)
Jan 07, 2010 | LG Heating & Cooling
ERROR CODE 81.018,E101
According to my reserarch this error usually refers to an EIO card error in slot 1.
you could try reseating the card , maybe in another slot.
A firmware upgrade could help.
if those don't help it may need a new card.it can't hurt to check any cables, make sure nothing is lose
Angela
Aug 29, 2008 | HP LaserJet 4650 Color Printer
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
