My LC55 3DTV has grey lines going vertically o it. What could this be from
  • Lisa hasty Dec 03, 2016
    Warranty expired. I replaced the main board
    But still having the same issue
    Top Expert:
  • Televison & ... Master
  • 79,865 Answers
Replace the TV and be done with it.
Posted on Dec 04, 2016
2 Suggested Answers
vmhreha
  • 77 Answers
SOURCE: grey vertical line appears on screen
It's a symptom of what everyone refers to as vertical banding. Have you tried a light grey screen to check for banding? It may be that there is a brightness difference between two bands that causes the line to appear darker. You may also find that there is more banding in other areas of the screen than you have realized.
but there's no simple solution; though some claim that unplugging everything from the tv and unplugging the tv power for 24hrs will help. I think that's a crock, but you can try it.
do you have a warranty?
Posted on Jun 17, 2008
Grey vertical line at the bottom of tv screen. 50" Hisense smart tv
The TCON board or the LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 26, 2016 | Hisense Televison & Video
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Bad copies/grey lines
hi do u have cleaned the scanner miror and the coppy glass may be coz of that u having that grey line
thanks
May 11, 2010 | Canon imageCLASS D761 Copier
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Thin Grey vertical line
Panel is bad you will have to live with it!
Mar 18, 2008 | Televison & Video
Grey vertical line appears on screen
I had the same problem with my Lnt4071f. I called tech support and they said it was a faulty panel and the entire set had to be replaced. If you have your warrantly still use it, if not you may just be able to replace the panel, but its expensive.
Dec 27, 2007 | Disteck P4204TWHD Television
Blank screen except for a vertical grey line through the middle
The horizontal sweep signal to the yoke is bad. Since other problems exist, the problem may be in the IHVT HI voltage transformer area. Check for bad solder around the IHVT pins and yoke plug. I hope this helps. Lee http://www.CrazyComputers.com
Jun 22, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
