Question about PfaFF Sewing Machines
I removed the rethread bobbin guide from my Pfaff Finesse 157 and the screw will not attach to the under pinning?
    Top Expert:
  • PfaFF Master
  • 8,304 Answers
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
Jan 14, 2018 | PfaFF Sewing Machines
My Pfaff Expression 2034 sewing machine is suddenly making an almighty mangled mess at the bottom - it doesn't matter how I re-set the tensions. What can be the problem?
Be sure to use a brand new needle.
Remove the upper thread and bobbin. Reinstall the bobbin making sure it is turning the correct direction and threaded properly in the bobbin case.
RAISE the presser foot and rethread the top thread. Confirm the thread pathway is correct.
Most often, knots (thread nests) occur under the fabric because the machine is misthreaded or the thread is not seated completely in the tension disk.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Sep 22, 2016 | PfaFF Sewing Machines
ChaMy pfaff 2144 will not stitch properly; pools masses of bobbin thread; Changed thread, tensions, needle etc still wont sew, please advise as I am so desperate to fix this problem
bunching of thread under material is a needle tension problem
tighten it up
proper tension is when it requires a small amount of effort to pull the thread through the needle eye
Jul 28, 2016 | PfaFF Sewing Machines
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
I paid to have my Pfaff tiptronic 2020 cleaned and repaired back in April. Haven't touched it till now. Although their test fabric looks fine with threads doing what they're supposed to, it doesn't work...
Rethread your machine. More than likely it is your bobbin threading is not in the guides right. When you rethread pull on both threads to make sure everything is seated in the guides right. Study your machine manual carefully.
Sep 18, 2017 | Sewing Machines
How can I factory reset my PFAFF 7550 sewing machine ?
Feb 28, 2013 | PfaFF Creative 7570
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
- resetting the timing
I have been an upholsterer for over 30 years, I own a Pfaff 145 and Pfaff 545. Both are basically the same. Whenever my timing is off, where the threaded needle won't connect with the bobbin thread, I have always had success in re-setting the timing by taking apart the entire bobbin case. Remove the walking foot and the plate it walks on. Remove the bobbin and dismantle everything underneath it. Keep each piece and its screws together, and remember the order in which you removed it (last goes in first, etc.)Remove any obstructions, thread, fluff, etc. Surprisingly, when you put it all back together, your timing will be back to normal. This has always worked for me, and I hope it'll work fo you.
Aug 11, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
