Question about Kitchen Ranges
When my burners went out on my fridgidare oven they went out one at different times but they made a pop sound when they did can that be the switch going out it not even a year old
SOURCE: Burners Blew
I had a similar problem while mine was still under warranty. Seemed like every time I used the oven and stove top for a major dinner it would short out and I would get an error code: F1:E6. They replaced the board under the display area, but it happened again about 6 months later. Turned out that when they made the oven they didn't insert a chimney like vent system from the bottom left side of the oven to the vent holes that come out the upper left side of the stovetop. This caused the panel to overheat and stop the entire oven from working. They replaced the board again and installed the "chimney vent system" and I haven't had the problem occur again (it's been 3 years!).
Posted on Feb 17, 2008
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
SOURCE: no power to stove after turning on oven and hearing a loud ''POP''
I called the Sears repair man.
Posted on Mar 28, 2009
SOURCE: Loud pop when I was baking with the oven on Convection bake
Did you resolve the problem with your stove.
Mine just did the same thing.
Posted on May 05, 2010
  • 112 Answers
SOURCE: The electric panel on my smooth top stove just
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 21, 2010
Using oven and there was a pop and it went dead...oven, stovetop burner, clock panel, oven light!
Your element has burnt out. Reset the breaker, and get a new element. You can usually see where it has gone.
Some older stoves have glass fuses hidden behind the front panel.
Apr 16, 2016 | Kitchen Ranges
Gas burners have a popping sound when trying to heat food in pans
Make sure you clean them properly, Call a repair man if noise persists.
Nov 06, 2013 | Magic Chef 31000 Gas Kitchen Range
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool Super Capacity 465 Gas Range. However all the burners on top will not click to ignite. I turned the breaker off and that back on again and it worked for a day or two. Now nothing will...
Power for the ignitors goes straight from the input power to the burner switches then on to the ignition module. The burner switches are in series parallel. Any one of them actuated will provide power to the ignition module.
See the schematic in this pdf file page 22 but page labeled pg 20:$FILE/4322089.pdf
When the ANY burner control is turned on all 4 ignitors do cycle.
Does the oven burner light? If not you most likely have a bad ignition control unit. Item 35 this link:
If the oven burner lights then you most likely have a wiring problem to the burner controls. There is ONE power lead that if it comes loose will cause all of the ignitors not to work.
You can use the https:// manual link above to gain access to the top of your oven. See page 15 of the .pdf file.
The igniton system is explained starting on page 19 of the pdf file.
Thanks for choosing FixYa.
Aug 18, 2010 | Whirlpool Kitchen Ranges
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Viking 4 burner gas range
if you are not hearing the faintest sound of clicking / sparking you could have a bad spark module or even bad burner switches i doubt that all switches went bad at the same time but its possible unplug oven check wireing to switches and spark module if you pull your burner knob off thats the switch starring at you follow wires and check for any loose connections
Dec 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
