Question about Hoover Washing Machines
Hoover OPH616 Cold wash light error codes. Is there a 16 flash code??
lords
  • 21 Answers
SOURCE: Original xbox
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
If you get an error 13 after this, please read up on the error 13 explanation!
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the (older) dashboard (4920) that older slayer cd installs and the new dashboard/kernel versions found in some new xbox's and found in xbox's that have been connected to xbox live (when you go on xbox-live, it'll upgrade your dashboard file to i believe it is now 5659.03. This dasboard is incompatible with the dash that (old) slayer cd installs (for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on most new xbox games! Be sure to 1st unplug your ethernet cable before you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar
Posted on Dec 30, 2007
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Posted on Feb 13, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
Hoover dyn8144 and related machines
Error code 03 followed sometimes by Error code 16
Check the usual drain pump and resistance of heating element
On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
Jul 10, 2015 | Hoover Washing Machines
Wot is e16 mean
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3450-hoover-optima-fault-codes-carbon-brush-motor.html
looking here i see that error 16
tells us that the heating element has gone bad and needs replaced
or the wiring is bad
could just be a loose plug on the htc/ temp regulator
you can check it but its pretty clear by the error
so look to hoover spares ebay etc espares etc for the cheepest if you feel like replacing it yourself
Dec 09, 2014 | Hoover DYN8163D8X White 600 mm Washer...
Hoover washing machine manual
HOOVER DYN 10144 DP What does it mean ERROR E13 CODE
Mar 01, 2014 | Hoover Dishwashers
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
What is error code 16
If it is an Optima with a brushless motor (I only have those fault codes for Hoover), 'E16' means 'water heater element insulation fault'. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Hoover Washing Machines
Can anybody tell me where I can find out the programme time
Generally a normal cycle on a washer is about 40 - 50 minutes, depaning on your options.
Dec 15, 2009 | Hoover Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
