Trying to fine a pilot for this heater - Heating & Cooling
When trying to ignite electric pilot light, when pushing button to ignite, pilot doesnt spark to create flame
Pull out sparking rod and lightly polish with fine steel wool. then put back together. Could be in control box but I doubt it. You will probably see mild corrosion on rod.
Apr 02, 2014 | State Water Heaters 50 Gallon Select SL...
Hayward spa pool heater pilot on, heat does not ignite burners
Don't really think the gas company would be checking your pool heater, they most likely just checked their gas connections. I would suspect a few things; control module, thermostat, gas valve, pressure switch. You say you get pilot light, and as long as it doesn't turn off and on, as if it is not being sensed, then I would suggest the control module is fine. If the pilot and main burner is controlled by the same valve, and your pilot light stays lit, then I would suggest the thermostat is fine. I take back the pressure switch since the pilot will ignite. I would check power to the gas valve solenoid and see if the control module is trying to open the gas valve. I would suspect low voltage, probably around 24v. If voltage is present and no gas, I would say you found the problem.
Apr 09, 2013 | Hayward H Series Pool & Spa Heater...
Can not get pilot to lite was working fine had to turn off gas will I changed out some water pipe went to relite and could not get pilot to lite
I would first make absolutly sure that I had all air bleed out of gas line to water heater. If you are trying to bleed air out thru pilot assembly this can take a long time because the opening in pilot orifice is very small. To speed up process if you have a union close to unit or flex connector,you can slightly loosen fitting till you can hear a little hiss of escaping air/gas. When you first smell gas immedieatly tighten fitting. Before you do this make sure there are no standing piloy lights or other sources of flame in the vicinity. When you smell gas and tighten fitting back up try to relight pilot to water heater.If you still can't get pilot to light I would remove pilot line from gas valve and burner. Check to see if you can blow thru it, visually inspect pilot orifice, and if blocked I would get a orifice cleaning tool from hardware or welding supply store. Be careful to select the right size for your orifice and clean it. Reinstall and try to light pilot again.Hope this helps. Thanks
Nov 17, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
My pro comp heater will light the pilot but will not light the heater. It just sparks attempting to light, after a while it will shut off completely.
Could be your thermocouple. The spark should light the pilot and the pilot lights the main burner but if the thermocouple doesn't pick up the heat from the pilot the igniter will keep trying to light it until it times out and shuts off to prevent gas buildup.
Mar 10, 2010 | Procom MN300EPC Heater
I'm trying to get my heater going this season. The pilot lights fine and heater will kick in but will only run 30 seconds max before it quits and I have to restart it. I've done this at least 20 times in a...
Does this have a fan attached to it or does the heat just stay around the unit. Does this have a thermostat or is it manually turn it on and off?
Is this in the garage or house?
1) Make sure no fans are operating when you do this.
An external fan can either **** the pilot off or blow it out.
2) Make sure if it has a thermostat that the sensing bulb located on the back is not picking up external
heat source.
3) If it has an external sensing bulb, put it in a bucket
of cold wtaer. Then try to light the pilot
Sep 30, 2009 | Procom (177653) Utility Heater
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
