Question about Coffee Makers & Espresso Machines
Coffee will not brew. I put water in the well holder, added a k-cup It makes noises but nothing happens.
    Top Expert:
  • Coffee Maker... Master
  • 51,518 Answers
BROKE might want to look for a new one
Posted on Dec 04, 2016
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
When the cup button is pushed, the maker tries to make coffee (five or six grinding type sounds) but nothing happens. The screen reads "brewing" but no coffee comes out.
Run the keurig with vinegar instead of water. Then run it 5 times with only water just to remove the vinegar taste. Do this once a month. Also there are pins that pokes holes on top and bottom of coffee kcups, find the pins and clean it by unclogging with paperclips or some thinner wire. Buy a K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 09, 2013 | Keurig Elite B40 Coffee Maker
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this helpful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Nov 11, 2010 | Keurig B60 Coffee Maker
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Aug 01, 2009 | Keurig B50 Coffee Maker
Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
Apr 01, 2008 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
