Question about Samsung Televison & Video
Samsung TV Model LN32A33OJ1DXZA picture is white with faint image. Is this a part I can change
  • 456 Answers
SOURCE: Bright white screen with faint images
If lighting did strike, you would be suffering power supply problems, due to a power surge from the strike.
The problem sounds like it could be related to the LCD panel becoming faulty or if your able to test inside the unit with a multimeter, you can measure the voltages from the printed circuit boards, especisly those suppling power to the LCD panel as well as the Logic PCB, A small printed circuit board you will find either attatched to the LCD panel. I hope this helps.
Good luck.
Posted on Jun 07, 2010
  • 75025 Answers
SOURCE: Hi, I have a samsung flat panel tv model UN29F4000, has sound and looks like no picture but if looked at in the dark you can see a faint image. Powersupply board changed with same results. Thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on Apr 18, 2015
  • 3462 Answers
SOURCE: How can I fix the picture on my TV screen that is white with faint image.
Check the aerial is ok, try another aerial on the set. It is unusual for FP tvs to have a bad picture. If the aerial is tested as being good try resetting the set to the factory default and then retune the cannels. I am assuming that you are receiving the signal through an aerial and not through cable/satellite dish.
The reset process may not not resolve the issue in which case it is probably time to get the services of a qualified technician. The fact that the picture stays on channel probably indicates that it is not a tuner error but something in the display ciruitry .
Posted on Jun 16, 2015
  • 75025 Answers
SOURCE: Bad picture, white with faint image.
T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: samsung model no. LN 32A33OJ1D code.
Posted on Dec 03, 2016
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
Aug 31, 2012 - Uploaded by
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ... > ... > Electronics
Jan 26, 2016 | Samsung Televison & Video
How do i fix sound but no picture on my samsung tv
Your tv has problem with the back light inverter. As you didn't specified the model number its not possible to know is it back light or CCFL one. How ever i have added video to know hoe to find the inverter check it.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
Sep 10, 2015 | Samsung Televison & Video
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung model no. LN 32A33OJ1D code. LN32A33OJ1DXZA wont turn on for nothing and someone try to charge me $500.00 to fix it need help !!
If I am corrct, It may just need a set of caps in the power supply, about $15 worth and may be 45 minutes of time,
see pictures here;
Sounds like someone is ripping you off or never works on repairing TV before, jhe ust gives you high estimate and charge you alot just for the estimate alone. That kind of repair shop gives all repair shops bad name.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Samsung LN32A330 32 in. LCD TV
32" Samsung LCD TV:
If you are a qualified TV/Video technician, you would not need to ask for help.
So, take your TV to a trained/qualified/certified technician, for professional trouble-shooting and repair.
Jun 06, 2011 | Computers & Internet
32" LCD Samsung TV:
Kodak Easyshare C763 White-out of outdoor pictures
Is this also apearing on the printouts or only on the LCD?
In any case if this is a constant occurance and in all SCN and dif. lightings I believe this is a repair.
If OoW the cost is aprox. 45 pounds + shipping to the repair centre.
Contact KODAK:
Nov 29, 2009 | Kodak EasyShare C763 Digital Camera
Televison & Video Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
