Question about Dayton Heating & Cooling
Hello, I have a Dayton electric heater that runs on 208v, I only have 120/240 at my home. Can this unit be run on 240? the model is 2YU68.
    Top Expert:
  • Dayton Master
  • 79,847 Answers
Yes it can run on 240V
Posted on Dec 04, 2016
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Oct 10, 2010 | Dayton D-F79 Electric Space Heater- the...
Dayton space heater 350,000 btu
Sounds like you have a bolwer motor or fuel pump that has bad bearings, as it runs, it starts to bind up, and get to the point where it is pulling to much juice to turn it, and the fuse does it's job and blows?
If you could give be a bit more detail, I can help you furthur.
Please rate the new guy :)
And get back to me, so we can get the problem fixed for you.
Lets get this fixed.
Sincerely,
Paul Gibson
Apr 04, 2010 | Dayton Electric Space Heater - Model D-F79
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Dayton 3ph 208V heater # 2yu72 not firing off - WHY?
I assume you mean its not Heating by not firing? If its 3 phase you may have lost 2/3's of your heat not just 1/3. Look at the safety's and find if 1 or more are open. Also there is a fuse able link on most elements and if you have had the heater try to run without a blower lately (or anytime in the past) the link may be out. These are usually installed where they "see" the heaters. If you have power to all the elements look for this or a bad element(s).
If your contactor is still not pulling in check for open safety's or bad timer.
Jan 20, 2009 | Dayton Electric Heater
Dayton kero heater wont fire
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Jan 15, 2009 | Dayton Electric Heater
Dayton electric garage heater
need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Nov 09, 2008 | Dayton Electric Heater
DAYTON 4LX48 HANGING HEATER
Exhaust is restricted or crack in heat exchanger. Get someone to look at it!
Feb 13, 2008 | Dayton (4LX41) Heater
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
