Question about Samsung Televison & Video
I am replacing my DLP chip on my Samsung TV can you clean the mirror that is behind the DLP chip with a cloth
Angel Petter
  • 114 Answers
SOURCE: can you clean the large mirror inside a DLP tv? If
Hello.. i will gladly help you..
first of all what is your tv model i need to now because there different typre os mirrors. and its really simple to clean the problem is figuring out were is it depending again on the brand..
if you send me the info i can show you how!
and you can clean it like you clean any mirror in this case extra carefully!
Posted on Jan 25, 2010
SOURCE: color wheel for Samsung HLR5688WX DLP TV
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
Posted on Aug 31, 2010
  • 5 Answers
SOURCE: Starlike flickers in picture of 57" DLP 1080p HDTV
The problem is the dlp chip on your light motor, you can order a new one at www.tvlampsforless.com.
Posted on Sep 22, 2010
CaptainHawk1
  • 345 Answers
SOURCE: how do i clean the mirrors in the dlp tv
You don't. They are sealed for a reason. If you're mirrors need cleaning, have a professional do it.
Posted on Nov 23, 2010
SOURCE: I have a mitsubishi tv
dip chip
Posted on May 14, 2011
My Mitsubishi TV has a small white dot on the screen
This could be something on the lens or mirrors. you can open one or both porthole covers on the left or right side of TV to determine if this is the cause. You can look at the mirrors & lens to determine if a bug or dust has gotten on either part. Then clean.
HOWEVER, the most likely cause is the DLP chip. this causes white & or black dots. May start out as one or two, then multiply.
See the following website for the proper DLP chip for your Mitsubishi model#:
http://www.shopjimmy.com/catalogsearch/result/index/?cat=24&q=dlp+chip
Jul 09, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have black spots on my samsung dlp tv
I had the same problem with my Samsung DLP tv a couple of weeks ago. I had to clean the lenses, mirrors and the DMD sensor to fix it, you must remove the rear cover to do this. If the mirrors and lenses were cleaned but the spots were still there, the final thing to do is to clean the sensor chip on the DMD board. It is located under the heat sink behind the small fan in the lower center of the rear of the TV. The DMD board will have to be removed to get to the back of the sensor. All you have to do is blow some dry canned air across it to remove the dust, do not wipe it with anything. The repair is somewhat complicated and you will probably have to realign the picture by adjusting the position of the DMD board when finished.
Jul 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP TV picture is blurry and washed out, has a new color wheel and lamp
this could be a dust build up in side on the mirrors and dmd chip open it up and care fully clean the inside with some caned air
Jun 30, 2009 | Samsung DLP HL-P5663W 56" TV
White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP with white spots
Hello rockel, As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
