Question about GE Hardware & Accessories
Instructions to program the GE digital timer 532641L3
Need instructions to program noma timer 052-8873-0
Copy following link, and scroll down and find same-similar timer, then click on manual and follow instructions in manual, then save manual to your computer, or open manual and add to your homescreen on phone or ipad, then when needed again search phone or ipad for manual or .pdf.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Gene
Dec 09, 2013 | Hardware & Accessories
I cannot program the "Off" time on my GE smart digital timer model 15071
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
GE 15071/ manufactured Tork SS720
Reset timer, and try again.
Push and hold reset button with paper clip or toothpick for 3-5 seconds.
Buy new timer at Home Depot and return defect with new receipt.
Otherwise instruction manual is straightforward, and would not accept ON time unless wired correctly.
Mar 19, 2013 | Hardware & Accessories
I can set the date & time and sunrise and sunset; however, the instructions to program are obscure to me. I want it to come on at dusk and go off at a set time.
1) Question posted under ST01C
Open following link for ST01C instructions with programming illustrations, plus wiring illustrations and battery information.
http://waterheatertimer.org/ST01C-program.html
2) The ST01C cannot be set for on-at-dusk and off-at-programmed-time.
3) If you have different timer than shown above, then add a comment with description of timer buttons for possible identification.
4) I have not tested the following timer, and it may be same as all other in-wall timers, but it is possible that the new GE 15312 sun-smart timer can be set for on-at-dusk and off-at-programmed-time. BUT I am only reading the instruction manual for a new product, before people write the company and then the manual gets changed.
Wiring for this timer is more complicated that ST01C
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
5) There are numerous outdoor plug-in type timers that offer on-at-dusk, and then off 2 4 6 8 hours later.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
6) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Instruction manual G1921 Grasslin Digital Timer
I don't have a manual for Grasslin G1921 timer.
You posted under photo of GE15079 which coincidentally has same buttons, but may or may not have same programming
Open following link to identify timer similarities.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
GE 15079 manual:
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
Add a comment and say if these timers are both programmable with same instructions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 04, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
I just installed a GE Smart Digital Timer. After I programmed the timer and went to manually turn on the light the light started to click on and off and the timer ticked?
Timer wiring instructions shown on following page:
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
Dec 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
42 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
