Question about Garden
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Posted on Dec 03, 2016
  • 272 Answers
SOURCE: How do I remove a wheel from my snow thrower
If it is the drive wheel you have to tap it out with a hammer and wood piece (to not damage it). It is pressed onto shaft.
Posted on Jan 29, 2015
  • 42615 Answers
SOURCE: Hello I have a craftsman 123cc single stage 4 cycle snow thrower. . Motor runs great with a little choke. When I put choke off it runs high and low. The spring linkages are moving back and forth
pull the carby and clean out the jets and passages
the carby cannot produce a constant air/f;ow mixture unless the choke is on and the governor is having difficulty keeping the engine speed constant
Posted on Oct 19, 2015
  • 333 Answers
SOURCE: snow blower sat for about 2 yr's had hard time getting it started.now it's surging when it's running.
Hello, I suggest you adjust the idle mixture screw on the carburetor to smooth out the surging.
Posted on Feb 14, 2016
  • 55 Answers
SOURCE: how to replace front auger cable on a snow blower
This picture is from an MTD but it should be the same.
Posted on Feb 16, 2016
  • 822 Answers
SOURCE: WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE SNOW BLOWER VS A DUAL OR MULTI STAGE SNOW THROWER
Single stage has one rotating blade that collects and exhausts via upper shoot.
26373343-4yt0j151ox44pteg2g1nkeph-2-0.jpg Two stage has one blade for gathering into the center and a second that exhausts via shoot.
The two stage works best!!
26373343-4yt0j151ox44pteg2g1nkeph-2-5.jpg Hope this helps?
Posted on Nov 26, 2016
Nov 26, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
How do I get the left wheel of a Murray snow thrower to engaged when the traction lever is engaged?
You will find there is a shear pin that has broken in the wheel that will not engage. Not sure if its a pin or bolt. I had to replace one several years ago.
Jan 24, 2016 | Murray Feiss Murray 27" Dual Stage Snow...
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Snow joe6200j blade does not rotate
First, does the motor make noise like it is spinning. If so, it is probably a broken drive belt between the motor and auger. The attached link shows how to replace the belt (pages 11-12). If the motor makes a humming noise but nothing is moving, something may be jammed. Bring the machine inside to melt any ice, and inspect the auger and belt. If there is no noise, make sure the extension cord has power by plugging something else into it. If there is power, you my have a bad switch or a burned out motor.
http://www.snowjoe.com/docs/SJ620%20621%20Manual_ENG(2).pdf
Feb 28, 2014 | snowjoe 18" 13.5 Amp Electric Snow Thrower
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
