Question about Health & Beauty
Please help! My go go ultra scooter won't charge after replacing batteries, pushing reset button and searching for,but not finding fuse.
  • 2,939 Answers
Turn of all power immediately...!1
As you can tell from the news...
people can be
SERIOUSLY hurt by batteries
as small as cell-phone batteries.
Batter handling is ALWAYS DANGEROUS...
Red
is POSITIVE
AND ... BLACK is Negative... Always!!
Check your polarity...
and make sure power is off when doing so...
BATTERY CIRCUIT can be quite dangerous... EXPLOSIVE.
Protective clothes, gloves & eye protection are STANDARD
You want to make sure you have a clear path to lots of FRESH WATER ... and ACID neutralizing agents near-by
(like: BAKING SODA... )
And YOU can perform WELL under excruciating pain...
IN a crisis situation... probably MOSTLY blind & disoriented.
(Professionals ROUTINELY have emergency practice drills).
Close supervision is BEST.
I'm JUST SAYING.
Posted on Dec 04, 2016
3 Suggested Answers
SOURCE: scooter will not charge
sounds like the gell batterys you can try a battery conditioner it may charge them enough for your charger to work again .if the batterys are not charged or used for a wile the batterys will not let the charger work they should be charged almost all the time
Posted on Oct 11, 2008
BAMOUT
  • 2478 Answers
SOURCE: I have a Go Go Ultra X 3 wheel scooter, just got 2 new batteries yesterday, it is fully charged, but when I turn it on, it goes beep beep and will not run, please help
Check the proper hookup Your manual should show you. If not come back, i'ii find you a diagram maybe
Posted on Jan 19, 2015
The only lever is the 1 in the back then is in the back position, keeps scooter still. Pushed reset button, nothing happens. It still beeps 5 times, it is a pride go go ultra x 3 wheel, please help
Hi, 5 bleeps implies the issue is related to the brake, check the little micro-switch situated on the side of the brake unit , this can stick fooling the scooter into thinking it still in freewheel mode...
if the rear disconnects away from the frame , check the connection here as well.
Regards
Rob.
www.gewizrepairs.co.uk
Jan 19, 2015 | Pride Health & Beauty
When I want to get scooter to go, it just beeps.
2 beeps=too low battery voltage
3 beeps=battery voltage too high
5 beeps=solenoid brake trip or free wheel mode
remove key then push then push the manual release lever in completely
6 beeps=throttle trip
throttle control lever may have been depressed while
inserting key so release control lever completely
7 beeps=throttle trip
throttle potentiometer fault or speed potentiometer fault
Oct 01, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I installed new batteries and checked fuses and reset button. Nothing happens when i try to turn it on
Hi, what could have happen here is the key switch has failed ?
There could be a number of reasons why the scooter is not turning on, what your location please ?
Regards
Rob
Jan 16, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Cant get batteries to charge
hi, you could have blown the fuse contained with the battery unit ?
If you have a electrical meter put the probes into the two outside holes of the charger socket, do not let them touch and check the DC here. No voltage shown then take the battery unit apart to locate the fuse. and check the leads have not come off the batteries.
Take care with dis assembly.
Regards
Dec 30, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
2002 Yamaha XN Teos 125 will not turn over
Hi, David before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters Scooter won start
TEOS 125 150 2000 pdf
OEM parts for Yamaha
Yamaha TEO XN125 Owner Manual
Aug 09, 2017 | Yamaha Motorcycles
My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
Apr 25, 2011 | Health & Beauty
Scooter will not charge
Check the fuses may have a Blown fuse
Check to see if power supply witch charges the scooter is not faulty
Regards; Aaron
Sep 13, 2008 | Pride Sonic 3 Wheel Portable Scooter
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
