Question about Maytag Refrigerators
Maytag refrigerator m4txnfyw not defrost - Maytag Refrigerators
  • Maytag Master
  • 2,942 Answers
Hello Suresh Mavadia,
This is the time to consider a repair ESTIMATE..
If you cannot find ANYBODY else... try sears.
(bad personal experiences... but hey... maybe it's just me).
- Always UNPLUG your refrigerator BEFORE "looking" at
it's electrical elements.... It is NOT safe... personal injury
is another issue you DO NOT WANT to ADD to you problem.
Make a mark (dot) on the center rotor... and a matching dot on the body of the timer
(Plug-in) ... check back an hour or two (in-plug)
If the dots have not changed their relative position the timer MOTOR is at fault ... THE great news is you have found your trouble ... and can defrost by manually advancing the timer... about 40 minutes... two or three times each day.. The bad news is you can still ELECTROCUTE yourself... Be careful.
There are three basic elements to MOST DEFROST CIRCUITS.
It is pretty easy to test and change out the DEFROST TIMER yourself (see below). On the associated drawing it will show you where it is... and what it looks like - there ARE DANGEROUS VOLTAGES on ALL these ELEMENTS....
(Do UNPLUG).
The other two defrost elements are
Defrost thermostat
specific purpose: to keep the defrost heater from getting HOT while removing the frost, typically located at the TOP of the evaporator)
and
the HEATER Element
(typically located at the BOTTOM of the evaporator)
Take pictures
and write the color AND number of your wire connections... Look for your original owner papers & part numbers...!!
WHILE... you a fighting with your problem to get it sorted out... FOOD HANDLING (POISONING) and waste are going to be your primary concerns...
Your refrigerator can still function (but poorly & unreliably)
and
possible WATER DAMAGE.
Do NOT use heaters to speed defrosting...
the soft plastics PARTS inside your refrigerator will be
DAMAGED an is typically irreplaceable.
Comment me back BEFORE getting into trouble... I come here daily.
Hope this helps.
http://www.appliancepartspros.com/search.aspx?model=m4txnfyw
defrost thermostat: watch the video:
http://www.appliancepartspros.com/whirlpool-bimetal-defrost-wako-wpw10225581-ap6017375.html
Defrost timer: watch the video
http://www.appliancepartspros.com/whirlpool-timer-def-w10822278-ap5985208.html
HEATER element wp2263749 (video)
http://www.appliancepartspros.com/whirlpool-heater-defrost-zoppas-wp2263749-ap6006902.html
Posted on Dec 04, 2016
    Top Expert:
  • Maytag Master
  • 77,202 Answers
You need to replace the defrost timer.
Where is defrost timer reset switch on a Maytag mfd2561heb
This model Maytag has a defrost control board and not a defrost timer. Your control board is located at the top of your refrigerator behind the display.
Jul 28, 2016 | Maytag Refrigerators
Initiate Maytag model mf12569veq2 defrost cycle
you will not be able to initiate defrost if its not defrosting the problem is one of three things.
control board, defrost heater and defrost thermostat can be found here http://www.repairclinic.com/Shop-For-Parts/a4b4d888747/Model-MFI2569VEQ2-Maytag-Refrigerator-Parts?RCAID=35836
Appliance 911
http://appliance911seabreeze.com
Jul 23, 2015 | Maytag Refrigerators
Maytag refrigerator not cooling and freezer has frost over coils/vents
Your refrigerator is not defrosting.
3 parts that can be contributing to your issue.
1. Defrost Timer/ Defrost board. Without knowing the model, if it is older, you have a timer, newer ones have a control board that does the same thing. Lots of maytags with the boards have issues.
2. Defrost Bimetal- found at the coils, the bimetal could be bad-cheap part.
3. Defrost Heater- least likely for a maytag to have a problem with the heater.
May 18, 2012 | Maytag Refrigerators
Maytag refrigerator moldel msd2756dew coils are freezing over
There are three magor parts that control the defrost on your model MSD2756DEW Refrigerator. The=> MSD2756DEW Controls are inside the fresh food compartment and behind the controls on the top shelf. In that photo is position 13 That is your ADC or adaptive defrost control part number=> 61005988
This is most likely the reason for not defrosting and causing the evaporator to ice over. The next part is the=> 61006199 Defrost Heater with Defrost Thermostat
sea_breeze_142.jpg Here is a PDF of a Maytag MZD2766GES and it has the same parts as yours so click here=> Maytag MZD2766GES Just use it for illistration or parts. Click here=> Defrost Heater Assembly to see that part and at bottom of page there is a short movie of how to test the defrost heater with an OHM meter. This is not hard to do if you want and I will be here if you need to ask other questions. If you have questions please let me know, Thank You, Sea Breeze
Apr 18, 2011 | Maytag MZD2766GES Side by Side...
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 28, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
MZD2766GES Maytag defrost problem
in fresh food part on top right, remove the housing assy.
Jul 21, 2008 | Maytag MZD2766GES Side by Side...
Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
Trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
