Question about Konica Minolta Di2510 Di251 Di250 Di2010 Di200 Di183
My konica minolta di2510 is showing co500. i figured out it is from the power board and i have checked fuses and they are ok. so what could be the problem of the power board
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Did u checked with other Fusing Unit on same machine with same power supply board. c500 due to Fuser heating error.
are u able to reset first?
Posted on Dec 13, 2016
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Check the fusing heatre lamp continuity and the thermofuse continuity.If is OK reset the trouble.
Jan 11, 2013 | Konica Minolta Di2510 Di251 Di250 Di2010...
Problem "don`t boot up" in
Check the power supplies. check power cord plugged in properly to the machine snug and tight recommend a tech from Konica Minolta
Apr 16, 2011 | Minolta Di2510 All-In-One Laser Printer
Tengo una konica minolta y meaparese con error co500 la maquina es modelo DI2510 me puede alludar a des bloquearlo gracias
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 23, 2011 | Minolta Di2510 All-In-One Laser Printer
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
Co500 code
check the thermistor; clean or change ; 2nd check fuse and thermostat using the tester';; 3 check the lock beside of the machine ,, 4 check the halogen lamp of the fixing unit',,5 check the board at the back of the machine;; i mean not mother board;; back of the mother board,, its a rectangular shape board';; if you do that, the machine will function correctly.
Jan 13, 2010 | Konica Minolta DiALTA Di200 Copier
I am getting an error code C0500 after changing the toner. What do I need to do to get the printer back online?
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Jun 27, 2009 | Konica Minolta Office Equipment & Supplies
I have a konica 7218 with a co500 error
Hello sir; Just need you to reset, turn power off thenhold down "stop" key while you turn on the power.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di2510 Di251 Di250 Di2010 Di200 Di183 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
