Question about GE Hardware & Accessories
Instructions for GE digital timer 532641L3
Need to know how to set the timer
Need instructions for a defiant brand digital indoor wall timer model 49815
http://www.jascoproducts.com/products/pc/GE-Timers-c35.htm
Apr 16, 2013 | Hardware & Accessories
Need instruction manual for GE digital heavy duty timer with astro
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html
2) Add comment and describe timer in detail for further assistance
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 18, 2013 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Need instructions to set time for 8 outlet power Strip timer Utilitech
Copy following link to identify power strip timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
Zilla, Utilitec, GE strip timers use basically the same format for programming.
For each ON time, there has to be a corresponding OFF time, and days for On and Off times cannot conflict.
Best guess: you have a conflict or incomplete on-off program.
With Zilla timer, there is added level of complexity since the ON-OFFs are set for different day and night outlets.
Add a comment with the exact timer model number so expert can read the manual alongside you.
Aug 31, 2012 | Hardware & Accessories
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
Iam trying to set the GE MODEL15089 and I seem unable to do so
I test timers. Some arrive defective.
GE makes a good timer, and sometimes the instructions are hard to understand.
1) When I have a problem with timer instructions, which is frequently, I write out the instructions which seems to help me understand.
2) Sometimes you need to reset the timer and then it recovers and works fine afterward.
Open link below to identify timer and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#15089
I am looking at the manual, and can see it has illustrations that show how the display should appear at each step.
1) The manual is too long for space allowed free answers, so I can't write out the instructions.
2) However, I suggest you reset the timer and then go through instructions carefully.
3) When you reach a specific point in manual that is confusing, simply add a comment to this post and I'll answer.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 29, 2011 | Jasco Ge 7 Day Digital Timer 1 Outlet...
I need the instructions for GE 15150 digital timer
The GE 15154 and GE 15150 have same manuals.
Difference between both timer is one has 2-prong outlet and other has 3-prong outlet.
See products at Amazon.
http://www.amazon.com/dp/B0035GAXA8/?tag=picc-20
http://www.amazon.com/15150-7-Day-Plug-Digital-Timer/dp/B0033ZV634/ref=pd_cp_hi_0
Manual for 15154 timer
http://waterheatertimer.org/pdf/GE-15091-Manual-eng.pdf
If this manual does not match your product, add a comment.
Your feedback helps fixya provide accurate and free answers for folks like you.
Dec 15, 2010 | Jasco 15150 7 Day Digital Timer 1 Outlet
Hardware & Accessories Logo
91 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
