Question about Watches
Can't seem to get pros can watch to turn on or charge , brandnew
Hello i have a problem with my Citizen Cyber Aqualand NX. He is flashing FILE. I have tried to do the garbage collection, but he said Fail. Also the Formatting of the Flash memory dos not work, and said...
I got last year same problem, easy to resolve :) I was doigng GC and i got my watch in failur exactly like yours. Solution? Buy 4 fresh, alkaline, good brand batteries. Put it in charger unit. Let the watch to charge for 12hours. After do garbage collection again or formatting if you cant do GC. If you got again fail, charge again it for 12 hours. I did it for 3 times and...the third days, I got "Done!" and solved :) It happens when battery is not full charged, so do GC just when is very charged. I love my Cyber, but sicne seems that GC collecting drink a lot of energy seems that low level battery doesnt let the inside flash memory to work well when try to format/GC datas.
Jun 01, 2011 | Citizen Promaster Cyber Aqualand Nx Dive...
Watch is about 7 years old. It went unused, but remained in light & charged for about a year. I started using it again last week. After a few days, the hands and date stopped turning. Doesn't...
The hands are not driven by the knobs. The knobs set the digital and the digital drive the hands. Find full particulars here: http://www.citizenwatch.com/COA/English/settings_int.asp?caliber=C651&interactive=C650 Your watch is not driven by a battery in the usual sense.
If after you do all that is asked of you by the instructions and the watch still will not run as it should, contact Citizen and get a return authorization. My Sky Hawk was dead dead dead. I returned it to them and they got it running and it is still running these several years later. Of course, today I keep it where it can get light daily. In my case, there was no charge for this service, which is not to say yours will be the same. Ask them in your e-mail to them. In my case, it didn't make any difference, I had to get my $500.00 watch working again even if it cost some amount of $.
Thank you for your interest in FixYa.com
Feb 24, 2011 | Citizen EcoDrive AT0100-51A Wrist Watch
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
Seems to be overwound, can this be fixed. winder will not turn and seems tight.
mcdevito75 here, This can happen at times with an older watch, Parts and springs in the mechanism with a little wear on them can be stretched ever so slightly as to not allow the watch to actually un-wind. At times this over-wound condition can be corrected, but please be aware this condition can also upset the time keeping of the watch also. I am Mike D. of RITE TIME BASICS, listed in the repair service directory here at fixya. There is no charge for us to look and examine your watch, we will let you know what we find and our recommendations for getting your watch back ticking. Any work we do is reasonably priced. You can simply send us your watch First Class postal, and the return to you by First Class Postal is FREE once work is done. Bottom of this page click on Repair Service Directory, then watches, we are RITE TIME BASICS or, you can choose one of the other fine watch repair people here at fixya.
Aug 19, 2010 | Watches
My Seiko never seems to charge enough to pass the first "indicator" scale. After a few minutes of charging it by swinging it back and forth, then wearing it all day and night; the next morning I get the "2...
There seem to be three possibilities
(1) the battery is not taking charge
(2) the generator is not charging the battery
(3) you need to swing it for much longer (one maker said swing their watch several hundred times!.
I suggest your try the easiest first i.e. No. 3.
If this does not improve things, go to your nearest dealer and discuss your problem with him.
If you need a service center, you can find out where one is by going to their web site (seiko.com) and click on "support".
Feb 13, 2010 | Watches
My watch is not moving . I want to know do I need to change the battery or it is self wind? ref. 384858.Thanks
Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
Jan 09, 2010 | Piaget Watches
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
Just purchased an eco drive watch. it will stop at night time even afer exposing to sunlight for more than 3 hours
I might have a warranty. Check it out with your dealer or from where you purchased it. To me it seems to be the its rechargeable battery seems to be not charging.
Jaswant Kamboj
Toronto
Jul 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Dec 31, 2006 | Casio G-Shock GW1200BA-1AV Wrist Watch
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
