Question about Home
Why does my kozi pellet stove keep shutting off after the fan starts to blow for a minute
4 Suggested Answers
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
  • 4736 Answers
SOURCE: Quadra-Fire Pellet stove-Pellet pot fills.
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Posted on Mar 10, 2011
Testimonial: "Thank you...don't know who Steve Tate is but will definitely look into Ignition Box replacement."
  • 27 Answers
SOURCE: I have a Kozi Bay
clean the jets
Posted on Apr 20, 2011
Testimonial: "Thanks for your helpful hints..."
My quadrafire 1000 pellet stove works great, but the 2nd fan will not shut off and continues to blow cold air. Any suggestions
when turned off the fans continue to run to cool down and exhaust fumes --turns off when firebox reaches a set temperature
Oct 27, 2016 | Heating & Cooling
When I light my pellet stove and push the start button the exhaust fan comes on but the smoke in the stove don't blow out the exhaust. What could be the problem?
Are you sure it is the exhaust fan and not the convection fan or the fresh air fan you hear? If it is the exhaust fan, check for blockage in the exhaust pipe.
Feb 22, 2016 | Whitfield Advantage II-T Service Manual
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
Kozi pellet stove wont lite keeps blowing fuse
If your Kozi pellet stove has an igniter (located in a steel tube under the fire pot), check to make sure the igniter isn't shorted out (dead short).
I recently purchased a used Kozi 100XL that had an igniter that was bad. I also found that, prior to me buying the stove, the old igniter had been twisted inside its steel tube under the fire pot bringing its two wires at the end of the igniter together. These touching wires likely were throwing circuit breakers for the previous owner of the stove but, by the time I bought the unit, this had resulted in a burned wire at the fan thermal switch where one of the igniter wires connects. After repairing the burned wire, I plugged the stove back in and a house circuit breaker was thrown. A new igniter repaired the problem.
BTW, Kozi has a better than excellent online customer service who will likely walk you through any problems with your stove. They did for me even though they knew my stove had been purchased used.
Jan 28, 2014 | Pool & Spa
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
