Question about Car Audio & Video
2006 XC90 Volvo center console broke/cracked at the bottom where it attaches to the base. Is this a common problem? I think it got bumped a few too many times as kids got in and out of car. only 20,000 mi. on car (and not many carpool days!) Thanks. Volvo won't cover it under warranty. I hear they've had this problem. Shouldn't they cover it? if not, do you know where i can buy a ''salvaged/used'' one? thanks!
repairpal
  • 128 Answers
SOURCE: 2006 Volvo XC90 Gas cover not locking
The normal operation is for the door to lock a several minutes after the doors are locked. Your owners manual should be able to let you know exactly how long it takes before it locks, then you'll know if it really is a problem.
Bret
RepairPal.com
Posted on Dec 01, 2008
roy7777
  • 109 Answers
SOURCE: 2004 Volvo C70 console light
IT IS A LITTLE BULB IN THE GEAR SELECTOR SAME AS ASTRAY LIGHT IT COSTS 10.00 AT A VOLVO DEALER AND THE REASON IT KEEPS BURNING OUT IS THAT BUMPS IN THE ROAD CAN SHOCK IT AND YES IT WILL BURN OUT
Posted on Apr 14, 2009
  • 185 Answers
SOURCE: The suspension system on my 2006 GX470 is acting up
you have a failed height control sensor. there are two on your vehicle in the rear. they need to be removed and checked for being frozen and or corroded inside.
75% of the time it is the left rear(driver side). on an 03 it will only be covered if you have an extended warranty.
Posted on Oct 14, 2009
  • 736 Answers
SOURCE: volvo xc90 2004 buzzing in steering wheel, clunck noise under car
that sounds like you are low on power steering fluid ... when the level gets low then the pump starts to ingest air and that produces a buzzing sound when you turn the wheel .....i would add or change the fluid and check for leaks and mechanical loosness in the under car linkages ...you can have that checked at your next oil change .
Posted on Apr 10, 2010
Testimonial: "Thank you, you were right I took the car in and they said the steering fluid was low. "
  • 75 Answers
SOURCE: 2006 Volvo XC90 side mirror control not working
Check your fuses to be sure it is not as simple as that. They fuse locations may be listed in your owner's manual. If you don't have the manual. Here is a link to find one online.
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/volvo/volvo-xc90-owners-manual-pdf.html
I hope this helps. God bless!
Posted on Jun 23, 2010
My steering wheel on my volvo 2006 xc90 locked now I cant tien the key
Common for the locks to go bad. You can tap the key while in the lock with a hammer and it will usually turn after that. It is usually a one time only fix so drive it to the repair shop and have it replaced. Takes several days as the lock assembly is codes to the vehicle and comes from Sweden-usually 3-4 days
Feb 21, 2015 | 2006 Volvo XC90
No air coming out from windscreen vent on xc90 2006 model
Check the vacuum lines goiing to the flapper. Probably a cracked line or loose connection.
Jan 18, 2015 | 2006 Volvo XC90
Low heat on passanger side of volvo xc90
most common fix is to go to a Volvo dealership and have them perform a climate control software upgrade and re-calibrate the climate control system
Oct 09, 2014 | 2006 Volvo XC90
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
Cant find the dip stick for transmission on 2006 Suzuki forenza has automatic transmision
Would you believe the car does not have a trans dipstick? This is becoming more common on the basis that it does not have to be checked often (they think). See here for a good explanation
http://www.ehow.com/how_8725779_check-fluid-2006-suzuki-forenza.html
Sep 23, 2013 | 2004 Volvo XC90
I'm an idiot and put my engagement ring in my change holder in my 2006 Chrysler Pacifica. When I went to put it back on, it was no where to be found. I believe it slipped behind the small crack
Print I hope this helps you,good luck.Randy
Removal & Installation
Instrument Panel
  1. Disconnect and isolate the battery negative cable.
  2. Remove the center console closeout panel by removing the left and right attaching screws, then the left and right panels.
  3. Remove or disconnect the following:
    Remove the shift bezel. Remove the transmission range indicator surround bezel. Remove the two screws attaching the front floor console to the lower instrument panel. Open the cup holder and remove the two attaching screws on the bottom of the cup holder. Open the bin and remove the two attaching screws on the bottom of the bin. Remove the front floor console sidewall attaching screws, three per side. Raise the front floor console and disconnect the wiring harness. Remove the front floor console from the vehicle.
    Fig. View of front floor console and shift bezel
    Fig. View of front floor console, showing attaching screws
  4. Remove the floor console base assembly by removing the two screws attaching the L-brackets to the instrument panel.
  5. Remove the nuts attaching the floor braces to the instrument panel.
    Fig. View of floor brace, attaching nuts, center brace, and floor bracket
May 02, 2012 | 2006 Chrysler Pacifica
I can't get the wheels off my 2006 Volvo XC90. I
This is very common, the center hole of the rim is whats holding the wheels on due to corrsion, you will need to hit inside of tire with a good size hammer and spinning it so you hit diffrent spots of the tire. the tire will break free.
Note try not to hit the rim as it will dent, wont harm it but try to avoid it.
You will note the build up on the inside center hole of the rim and also on the center hub. use a steel brusk and some fine sand paper to clean.
After you clean apply some lube grease around hub, this will make the wheel go on and come off alot better. hope this helps.
Mar 04, 2012 | 2006 Volvo XC90
Apr 14, 2010 | 2006 Volvo XC90
I need to attach the mirror to the motor on my volvo xc90. Is there a technique to use so I want break the mirror or any attachments
just push it on there as evenly as possible make sure you plug in heating wires first[if equiped]they are pretty tuff ive never broke one
Mar 21, 2010 | 2004 Volvo XC90
Volvo xc90 front seat cupholder cover on center isnt working
I had a problem with the back seat cup holders. You can actually remove the whole console. I took mine to the dealer and they fixed it for free. They did not even sell me my car. Here is the link to the manuals:
I hope this helps!
Jan 23, 2010 | 2006 Volvo XC90
Car Audio & Video Logo
151 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
