Question about Makita Drills
I have a makita BHP454 cordless drill that I overheated while working, start smoking. Now its not turning clockwise anymore. Is it fixabl? If yes what part(s) needs to be replaced?
    Top Expert:
  • Makita Master
  • 8,376 Answers
Posted on Dec 03, 2016
Testimonial: "do you think i can change the brushes and it will work normal agian? or it could be the motor cause it smoked badly and when i start using it again then it stopped turning clockwise."
  • NOEL
    NOEL Dec 03, 2016
    the only way you will find out if it will work after you have replaced the brushes is try it.if it does not work then you will no its the motor that may of gone.
Can any one tell me wear can get gear box break down on makita cordless drill bhp454
It seems that Makita will not breakdown the gear assembly. Here is the complete gear assembly for your drill. https://www.ereplacementparts.com/gear-assembly-p-201383.html
Apr 01, 2017 | Makita Drills
Makita bhp454 overheated, not turning clockwise.
It is very common for the armature to overheat and melt down.
Open it up and inspect the armature, it will be very obvious it is burnt.
If it is the case, replace the brushes (#16) and the armature(#14)
Makita BHP454 18V LXT Lithium Ion Cordless 1 2 Hammer Driver Drill Parts
Dec 03, 2016 | Makita Drills
Mikita BHP453rf instruction manual
I am a Makita dealer and service center and I cannot find a Makita tool with the model number BHP453. They do make a BHP452 and BHP454. If you go to the Makita website at www.makitatools.com and put BHP45 in the search box you can get the manuals and breakdowns for those tools and see if they match what you have.
Aug 27, 2012 | Makita Drills
I have a Makita BHP454 cordless drill and lately when I pull the trigger it won't do anything. The lights work but it doesn't move. I have to give it a hit to make it work again.. What would b the...
The first thing to check is the battery: is it fully charged, are the contacts in good condidtion and do they make good contact with the contacts on the switch.
Next thing to check is the brushes. Remove the rear cover and check the brushes and springs that hold them down on the armature. If the brushes are worn to where they dont' make good contact or the springs are not holding them down with enough pressure they won't make good contact and sometimes a good hit will make them touch enough to work again. The brush part number is CB-440, if the springs are bad you have to replave the whold brush holder, part number 638614-1.
Feb 14, 2012 | Makita Drills
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
I have a Makita #6347d, when I have been using the drill I had some smoke from the battery connection to the drill and the housing of the drill had some smell of smoke. Whats up? Thanks, Bill
Check what gear you in, the Makita will smoke if you exert to much torque, consider buying a decent impact driver? If its not under much pressure then it may be a fault with the drill. I have owned one and it was reliable but sometimes under-powered for an 18volt compared with others on the market.
Hope this helps
Jon
Oct 23, 2010 | Makita 6347DWDE 18 - Volt Cordless Driver...
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 2071 Smoking, probably overheated but still working
When an AC motor is stalled, very high currents pass through the motor windings and melt the insulation on the windings; the smoke was the result of the motor winding insulation being melted. This causes a reduction in motor torque and premature failure.
You should suggest that your neighbor buy you a new drill and he keep the one that he ruined.
Aug 31, 2009 | Makita Drills
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
301 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
