Question about Samsung Televison & Video
I have a samsung tv model# UN40H6203AF, it is two years old and now has no picture or sound even if I press the menu button. What would cause this and how do I fix it?
    Top Expert:
  • Samsung Master
  • 75,311 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Posted on Dec 03, 2016
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Samsung LED TV UN40H6203AF No Sound. No Picture. Stand by light works but tv doesn't turn on. Also no Backlights. Flashlight test shows letters on screen after pressing menu button.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 30, 2017 | Samsung Televison & Video
Samsung led TV model UN40H6203AF no picture no sound no backlights. Flashlight test shows letters on screen after pressing menu button. Standby light blinks 5 times after turning on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 29, 2017 | Samsung 40" Black LED 1080P Smart HDTV -...
I turned off the tv last night like every night but this morning there was sound but know picture. I checked all the cords/cables I unplugged and plugged them in but nothing. I cant even get the menu to...
What is the make and model of your tv? If this is an lcd or plasma, is there a backlight that comes on when you press the power button? If this is a dlp tv, do you see the lamp light from the back of the set? If you give me make and model I can download service manual to give you more informed information.
Apr 03, 2011 | Televison & Video
I lost my sound on my Samsung LN-T4061F tv. it was plugged into my stero.. was fine.. and now no sound. Not even on the regular tv. HOw do I get the sound to work at least on the regular tv?
hi,
i think ur tv's internal mute function is ON. change it to OFF through the following setup.
1. Press the MENU button to display the menu.
Press the ? or ? buttons to select "Sound", then press the ENTER button.
2. Press the ? or ? buttons to select "Internal Mute", then press the ENTER button.
3. Press the ? or ? buttons to select "OFF", then press the ENTER button.
Press the EXIT button to exit.
ok
Dec 14, 2010 | Samsung Televison & Video
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
