Question about Locks & Locksmithing
My Garrison keyless lock only works while the key is in the lock. When I take it out the buttons won't lock or unlock anymore. You can hear it trying to work but no dice. Model 046-2668-2
  • 33 Answers
SOURCE: locks not working properly
been there ------open up the rubber connector between the drivers door and the body [by the door hinges ] the wires break from flexing. just solder or **** connector them back together. it helps to add some wire to one of the broken ends to make it easier to connect . there may be more than 1 wire broken
Posted on Feb 15, 2009
  • 77 Answers
SOURCE: keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
Posted on May 12, 2009
ghost45
  • 1280 Answers
SOURCE: 2004 Hyundai Sonata door lock functions inoperable.
you have a bad relay.. the 'lock' relay.
Posted on Sep 23, 2009
  • 105 Answers
SOURCE: My 2002 Honda Cr-V's keyless remote has stopped working.
drivers central door locking module is kaput and needs flinging as far as you can then replace it with a new one or a salvaged one
Posted on Dec 28, 2009
  • 571 Answers
SOURCE: Keyless Remote Won't Work - But Car Starts
The remote receiver unit is located in the rear view mirror. This may be faulty. Since the car is new (less than a year?) you still may have the factory warranty.
Posted on Jan 16, 2010
Testimonial: "Thanks for the help. "
Garrison keyless door lock, just bought it and I'm tying to lock the door as it suggest in the manual pressing the set key and it squeals and it doesn't lock the door! What could this be? So annoying!
have installed a few of these you have to make sure that the bolt on the lock is very easy to move lock and unlock binding in the door jamb adjusted it we can easily move it with your hand from Lock to unlock that should take care of it
Apr 24, 2016 | Cars & Trucks
Ford explorer door lock
Mine did not have the keyless pad problem - but replaced switch after checking it with ohm meter - showed switch was electrically stuck in unlock.
Jan 31, 2014 | Cars & Trucks
Unlocking the door
Same issue. But I have Garrison instead.
Dec 29, 2013 | Deadbolt Weiser Powerbolt 1000 Keyless...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
Wireless Key Remote door & trunk opener won't work with trunk anymore
When you press the trunk open button, do you hear any "release" noise come from the trunk area? The issue may be a bad battery in the key fob OR there could be an issue with the transmitter located inside the vehicle. Do the doors lock and unlock properly? is the vehicle equipped with security or immobilizer? please advise
Jun 03, 2012 | 2006 Toyota Camry LE
98 A4 quatro, broken keyless entree system
can you hear the pump trying to work?
Jul 30, 2008 | 1998 Audi A4
Locks & Locksmithing Logo
177 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
