Question about Makita Drills
Makita bhp454 overheated, not turning clockwise.
    Sergeant:
  • 206 Answers
It is very common for the armature to overheat and melt down.
Open it up and inspect the armature, it will be very obvious it is burnt.
If it is the case, replace the brushes (#16) and the armature(#14)
Makita BHP454 18V LXT Lithium Ion Cordless 1 2 Hammer Driver Drill Parts
Posted on Feb 19, 2017
Can any one tell me wear can get gear box break down on makita cordless drill bhp454
It seems that Makita will not breakdown the gear assembly. Here is the complete gear assembly for your drill. https://www.ereplacementparts.com/gear-assembly-p-201383.html
Apr 01, 2017 | Makita Drills
The cutting disc on my makita 5806b spins anti clockwise causing damage if i cut laminate from the top and i need it to spin clockwise
You could turn the laminate over.
The proper tools would be either a router with an edge bit ( what I and most cabinet makers use ) or a low tech utility knife (carpet knife ) yep just a razor knife - really it works.
Don
Jun 12, 2014 | Makita 10" Miter Saw LS1030N
Mikita BHP453rf instruction manual
I am a Makita dealer and service center and I cannot find a Makita tool with the model number BHP453. They do make a BHP452 and BHP454. If you go to the Makita website at www.makitatools.com and put BHP45 in the search box you can get the manuals and breakdowns for those tools and see if they match what you have.
Aug 27, 2012 | Makita Drills
I have a Makita BHP454 cordless drill and lately when I pull the trigger it won't do anything. The lights work but it doesn't move. I have to give it a hit to make it work again.. What would b the...
The first thing to check is the battery: is it fully charged, are the contacts in good condidtion and do they make good contact with the contacts on the switch.
Next thing to check is the brushes. Remove the rear cover and check the brushes and springs that hold them down on the armature. If the brushes are worn to where they dont' make good contact or the springs are not holding them down with enough pressure they won't make good contact and sometimes a good hit will make them touch enough to work again. The brush part number is CB-440, if the springs are bad you have to replave the whold brush holder, part number 638614-1.
Feb 14, 2012 | Makita Drills
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Lock nut on Makita 9069 is stuck & I can't loosen it. Using the lock nut wrench, but it won't budge. Any suggestions?
Make sure you are turning wrench and nut clockwise to remove nut and counterclock to put back on,you will never get nut off if turning counterclocwise,threads pitch is opposite to screw pitches.
You are tightening and did not know it maybe???
Other option:
Need to put lock nut wrench in a vise jaw and clamp, then place tool on wrench and press down and turn. This should give you added leverage to break loose nut,and btw make sure to turn clockwise to unscrew and clockwise to tighten,this is opposite of what you might do to tighten or untighten
Apr 09, 2009 | Makita 9069 9" Angle Grinder
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
298 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
