Question about Refrigerators
On a rangemaster sxs cream fridge freezer the panel on the freezer door has a fuzzy control setting but this keeps lighting up and bleeping and will not stop
4 Suggested Answers
SOURCE: rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Posted on Apr 04, 2010
  • 83 Answers
SOURCE: Re Rangemaster SXS Fridge Freezer.
Hi there
This means you need to change your water filter
Regards
Gordon
Posted on Apr 21, 2011
beefgehrke
  • 50 Answers
SOURCE: The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Posted on Oct 13, 2013
Fridge not working
  • Are you getting power to the unit
  • do you see the light and fan working
  • do you hear the compressor running
  • how old is this unit.
Mar 03, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
Rangemaster fridge freezer not freezing temp 0.2 what should it be
could be condensation from a bad door seal? might also check the tempeture control thermostat
Feb 14, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
Wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Jan 17, 2010 | Refrigerators
Oct 27, 2009 | Refrigerators
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
