Question about Kenmore Dishwashers
My Kenmore dishwasher model # 665-1603 clean light flashes
My Kenmore dishwasher model # 665-1603. the clean light flashes continuosly. The manual says the dishwasher has malfunctioned. What could the malfunction be?
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
SOURCE: "Heater Circuit Malfunction" Kenmore 16033
Ditto here!  Same blinking light.  Repair guy said we need new computer board and heating circuit for $350 (and it cost me $60 to get this BS assessment).  I just tried the button sequence and ... wah lah! ... all better.  THANK YOU!!!
Posted on Oct 25, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light flashing
This is a communication error between the control and motor. Try resetting the control by pressing the following keys with in 5 seconds.
HEATED DRY, NORMAL, HEATED DRY, NORMAL
after about 15 seconds hit cancel then the control should be unlocked. If the problem comes back the problem is most likely with the motor for the pump. Check with your warranty, some of these Kenmore models may be under warranty
May 08, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher clean light flashes 7 times
you need to change the switches on the door lock and put it in diagnostic mode to clear
there is 3 or 4 buttons on the right side of the control press the inside one then the outside one back and forth 3 or 4 time after the kights start flashing press cancel
Jul 03, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
The cleaning LED flashing and dishwater not working
The blinking clean light is an indication of a malfunction. Which circuit is causing the problem is determined by the number of flashes. Sometimes these error codes can be erroneous, however. If you wish to reset the light to see if you have a glitch, or a legitimate problem, the following link may offer you some assistance:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
If the error reappears you will need to refer to the tech sheet that comes with your appliance. The sheet is usually located inside the lower toe panel under the door.
If you have questions, please let me know. I hope you find this information helpful.
PS Your dishwasher may have a different series of buttons to push to reset the error, but the steps are similar. If you do not have the same configuration as outlined in the link I provided, refer to your tech sheet.
Jun 11, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Feb 22, 2009 | Kenmore Dishwashers
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Nov 27, 2006 | Kenmore 24 in. 16023 Built-in Dishwasher
Dishwashers Logo
231 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
