I'm getting a ul code upon agitation even when empty and it also started leaking during agitation. MTW 6600T I removed the back cover and appears to be leaking from left center.
  • 1314 Answers
SOURCE: whirlpool LSR7233EQ0 Washer Leaking
just pull it off.on the control panel you will see two screws on the front or back back them out as far as you can then pull the control panel slightly forward then flip it back there are two gold clips on the body of the washer with a screw driver holding the handle pointing toward the back pop the two clips off but remember how they go as it can be tricky putting them back on if you don't then tilt the washer at about 45 degree's and pull it forward disconnecting any wires you see then take the body of the washer off and you can start working you will need a special wrench to get the tub block nut off or a small pipe wrench and hammer will do can get wrench fairly cheap at an appliance parts store now when you put washer cover back on tilt to 45 degrees and look down .the front of washer goes under frame and the sides go on top there are two rectangular slots that fit on tabs on the frame look close and you will see
Posted on Jan 01, 2008
SOURCE: code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Posted on Aug 06, 2008
  • 30 Answers
SOURCE: fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Posted on Sep 04, 2008
  • 1462 Answers
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Posted on Oct 16, 2008
  • 3513 Answers
SOURCE: water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting
Posted on Aug 10, 2009
Micro ran empty for @ 10 min. cover on the top - says do not remove except to service- melted.I removed it and called parts to get a new one. Should I operate it once I get the new piece?
What melted?
The cover?
More than likely the Magnetron self-destructed.
Nevah Evah.... run a micro while empty.
The high-energy waves have nothing to absorb them, such as water or food, so bounce back into the Magnetron antenna that produced them, creating fireworks.
As for operating, as long as door cut-out switches have not been tampered with, there should not be a problem.
However, if magnetron magnets were damaged during the surge, you could get sparks or arcing. With bowl of water in oven, start and be ready to stop quickly if sparks, arcs, or smoke appear.
Be very careful of not touching wiring, even unplugged. The HV cap can store lethal discharge voltage, even when off..
Nov 20, 2017 | The Office Equipment & Supplies
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Kenmore Elite Oasis He. During the final spin cycle the load becomes unbalance and the drum beging jumping up and down until the UL code is displayed, this happens on every load except when empty...
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My hotpoint future fza34 is leaking from underneath
you need to get to the back of fridge and ul notice a tray full of water ontop of the compressor. remove tray and empty water out. when replacing v important to make sure it is sitting level on compressor again.
there is also an underlaying prob here, maybe alot of condensation on shelves also??
ensure doors are closing properly and saels are in good shape, also avoid putting warm food in fridge and make sure liquids are covered. this should stop tray filling with water and leaking
Sep 23, 2010 | Hotpoint Freezers
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code ul appears shortly after start up
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
