Question about Refrigerators
The panel on the freezer door keeps ringing the fuzzy button and we cannot stop it or turn it off
2 Suggested Answers
SOURCE: over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Posted on Jan 30, 2009
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
My samsung frige, french doors keeo ringing
Mar 19, 2015 | Samsung Refrigerators
Smeg refrigirator keeps beeping without stop
Mar 09, 2015 | Smeg Refrigerators
Keeps beeping without stopping
I have turned my fridge freezer off during 5 weeks. Since I'm back it's back on again, it cools and the freezer is freezing... but every day it rings and indicates that the freezer temperature (the re
Laurie a lot of people forget to leave the fridge and freezer door open slightly and the water from defrost hiding behind the rear wall of the freezer will keep the inside of freezer and fridge damp this will cause the freezer fan motor to rust and stop air circulation. Can you provide a model number? Thanks John Tripp Appliance 911
Contact me Here
Oct 22, 2014 | Refrigerators
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug.
This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old.
Hope this helps. Best wishes!
Jul 23, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Mar 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice trap on freezer door is broken
I am having the same problem. I called Sears and am told I have to replace the entire freezer door! You can take off the front panel -- there are clips at the bottom underside of the panel.
Did you resolve your problem?
Jun 15, 2008 | Whirlpool Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
