Question about GE Dryers
My ge profile turn on but would not run,i checked sensors they all goods, control board lights on,all switch checked are ok,but the dryer will not model is dpsb519rboww thanks
  • 822 Answers
Try the capacitor next to the motor....
Posted on Dec 04, 2016
Dryer has power, control board lights up and beeps when touched, but dryer won't start
I would check the door switch. if switch is good, then control board might not be recognizing switch as being closed. Check for proper voltage at the plug. any volts under 208 is bad.
Nov 18, 2015 | GE Profile DPSB620ECWW Electric Dryer
Thermal fuse location
It's not a thermal fuse..You're getting power so issue is either the board or the fuse inside the board..that's what you should be looking at..All switches are mainly for safety
Mar 16, 2014 | GE Profile Harmony DPGT750EC Electric...
I have a GE dryer model # DPGT750EC1PL When I press the power button it does not come on, but when I open the door the light comes on. what part do I need to replace?
check the thermal fuse located on the element housing below and to the right of the drum assy. also you can tie all 3 leads of the door switch together to test this another problem is there the electronic control boards as there is a start relay on the line voltage side of this board and is controlled by the low voltage interface which is what you use to select your preferences to dry clothes from,normally theres a fuse located on this board or possibly the interface keypad could have one or more keypads stuck rendering the dryer dead
Jul 27, 2012 | GE Profile Harmony DPGT750EC Electric...
My GE profile model dpgt750ec dryer will not turn on - checked breaker okay, light comes on inside the door, but no power when attempting to turn on
Recheck breaker turn the breaker all the way off and then reset the breaker. Then try a different cycle. like air only or something different than you normally use and see if it works then. Motor could be out or The control switch. Make sure you are looking at a double pole 220 breaker. hope this helps.
Dec 19, 2010 | GE Profile Harmony DPGT750EC Electric...
The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Jul 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer display flickers and lights flicker
open top and check connections, unplug power and reconnect after done. if this does not solve it then I would replace display board. this dryer is made by LG, controls should be good.
May 04, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
