Need to reg my tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Dec 03, 2016
Im trying to hook tv up with reg antenna and basic chanels. Tv scans chanel but doesent come thru
Do you have a converter box? You need a device called a "Digital To Analog" converter.
May 19, 2017 | Televison & Video
How to set up for cable
do you have a HD cable box or reg?..HD box you need the cable w/ 3 wires red/blu/green........reg just need the coaxial cable...lets start with the HD plug cables from (out) the box to in (tv) most likely this will be the component (source, it can also be your digital) on the tv when you are viewing....the reg set up is coaxial cable out (box) to cable in (tv) set the source to cable on tv...also not the tv must be on Ch 3........
feel free to rate the help
Aug 05, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Tv won't turn on
I donot know the model # but if it is 11 years old, it is the classic we have a lot of bad caps. If the fuse is good, this is all you need. Maybe 10 or 15 of them can be found with the cap check. If the fuse is burned, replace the H.O.T., the poweline reg. and that small voltage reg just two inches away. [other side of heat sink] See the NTE cross ref bible for semiconductor replacement. The resistors are usually good. Caution High voltage inside!!!!!!!!!!
Sep 03, 2009 | Zenith Televison & Video
New tv to play the playstation3 ?
Are you using the reg 3 colored plugs and RGB setting on the PS3?
It should work on a reg TV.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
THE TV IS BLANK EXCEPT FOR THE LETTERS AV IN THE TOP RIGHT HAND CORNER, I CAN'T GET ANY RESPONSE WITH MY REMOTE CONTROL.
you need to take your tv out of the audio video mode (av is for when you run a game or dvd player into the jacks on the outside of your tv) the renote will have a botten to change to reg tv
Dec 06, 2008 | Televison & Video
Triple monitor set up
That is because the tv is a connector for the tv only.. the other ones are for the computer monitor only.. you can only set up one at a time... If you want the tv one then only get the tv one to work...
Mar 24, 2008 | ASUS A9600GE/TD RADEON 9600, (128 MB)...
TV turns it self off.
your ic reg str (some )need replace and check the cap big at side .
Jan 05, 2008 | Sanyo HT28745 28" TV
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
Televison & Video Logo
Top Televison & Video Experts
