Question about Dewalt Drills
How to change power cord in a Dewalt 1/2 VSR Drill , DW235G?
    Top Expert:
  • Dewalt Master
  • 8,204 Answers
Where does the green wire connect from the power cord on a dewalt dw 236 drill
The green wire is always the ground pin (ground connection)
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
Where does the green wire from the power cord attach to on a dewalt dw 236 drill
The green wire is always the ground wire. It should be connected to the ground pin on the power connector.
Hope this helps.
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
How do I connect the chuck key to the chuck key holder on the DW235G drill?
Easiest is to tape the chuck on the cord about 18" away from the plug, this way-for safety reasons, you should disconnect it before making adjustments (with the chuck in hand and you accidentally pull the trigger and bad things can happen.)
Aug 27, 2013 | Dewalt 1/2 Hammer Drill DW511
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
How do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Jun 09, 2009 | Dewalt Drills
Drills Logo
143 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
