Question about Refrigerators
Cooler does not shut off when cold, ever thing freezes, I am thinking temp controller?
  • 552 Answers
Posted on Dec 09, 2016
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
39 ltr engle fridge freezer wont shut off when at temp
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Cooler coil freezing up
Way too many thing's can cause such problem's. Most important with bottle coolers are clean condensor, good condensor ventilation, do not overstock and block evaporator circulation. Then you get to component failures, failed thermostat or improperly positioned sensing element, failed evaporator fan, icing of the evaporator section from fan or gas charge problems, contamination in gas curcuit causing cap tube blockage, compressor overheat shut downs from real or defective component issue's. Trouble-shooting is a plan for cause elimination, start with the simple end and move out from there?
Jun 29, 2009 | True TD-95-38-LT Beverage Cooler
White westinghouse dehumidifier freezing up
hopefully its not the coolant pump seizing. the only simple thing that goes wrong with those is the water full switch, which turns off every thing. try playing with the float thing in the tank, you shoud here clicking of the switch on and off
Jun 15, 2009 | Whirlpool AD70USS Dehumidifier
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
