Question about Denon DHT500SD System
Denon dht500sd /when playing DVDs we get the sound but no picture,a new laser has been fitted but it is still the same
  • Denon Master
  • 5,348 Answers
It's probably an electronic fault. You need to trace the path of the picture signals after it leaves the laser. You might need the circuit diagram for it. But suspect any major IC that deals with the picture.
Posted on Dec 07, 2016
Plays dvds not games
I,d suggest that this is a laser related Problem
As CDs And DVDs use Single Layers. Whereas The Games Use Dual-Layer Or Blu Ray Lasers.
You may need a new Laser Unit Fitting. if Still Under warranty, It may be practical to return for repair. as A New Laser Unit is in excess Of £65.00 Or $100.00.
Mike @ Compurepair.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Schemat denon dht500sd
type in dht500sd schematic u should get excellent results
Aug 08, 2009 | Denon DHT500SD System
Denon dht500sd surround system
You need to check your speaker wire connections at the speakers and at the amplifier. You must have a positve and negative speaker wires touching. If you check them and still same result you need to unhook all speakers from amp and speakers and hook up one speaker at a time to see if you get message for each speaker and when you finally do you will know which speaker wire and speaker is giving you a problem.
Nov 07, 2008 | Denon DHT500SD System
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
May 25, 2008 | Denon DHT500SD System
DVDM 1805
it sounds like you might need to clean the laser eye, try that and get back with me
Dec 10, 2007 | Denon DVM-1805 DVD Player
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
Denon Home theatre System
If TV has AUDIO OUT and you hook up AUDIO OUT from TV to AUDIO IN on your system, it should play.
Oct 06, 2007 | Denon S - SERIES PREMIUM HOME THEATER...
Denon DHT500SD System Logo
111 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
