Question about Gemmy Toys
I can't get my gemmy santa to lock in collapsed position
SOURCE: Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Posted on Jan 02, 2009
SOURCE: I have a lifesize grinch
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Posted on Dec 18, 2010
Testimonial: "Thank you so much,I would never have figured that out..... Peggy !!!!!!!!!"
SOURCE: My Gemmy Singing, Dancing Santa
mine want spring up either. HELP
Posted on Dec 24, 2010
janchr
SOURCE: How do I get 6' Tall Collapsible Santa to full size
the one i have has a large button on the base you just step on that button and santa pops up to full size and reverse it when you want to collapse again
Posted on Feb 29, 2012
SOURCE: I have the 48" gemmy singing, dancing santa. We
You simply press down on both shoulders at the same time and he'll pop up to full size.
Posted on Dec 07, 2013
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
How do I store my gemmy santa?
Put it back in the box in which it arrived.
Jan 06, 2015 | Gemmy Toys
My life size Santa stopped dancing. How do I fix?
The first step would be to check all of the connections. If they are fine, next is to check the power supply for voltage using a meter.
Dec 03, 2014 | Gemmy Life-Sized Animated Santa
Electrcal curcuit for gemmy santa please
www.gemmy.com or www.yardinflatables.com
Sep 29, 2014 | Gemmy Life-Sized Animated Santa
Can you buy the power cord for the gemmy santa clause
Any the adapter plug is identical to a rechargeable drill and the volts for it are 9V hope his helps
Jun 17, 2014 | Gemmy Life-Sized Animated Santa
I need an instruction manual for gemmy lifesize singing and dancing santa
The shoulder thing worked! thanks so much!! i was all over that thing!
Dec 10, 2012 | Gemmy Life-Sized Animated Santa
I have a lifesize grinch who stole christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the sitting position..... pmaguire@cfl.rr.com
good luck
Dec 18, 2010 | Gemmy Life-Sized Animated Santa
I have the same problem. Ever find an answer?
Dec 13, 2010 | Gemmy Life-Sized Animated Santa
Dec 11, 2009 | Gemmy Toys
Toys Logo
37 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
