Question about Vacuums
How to find out where a blockage might be. - Vacuums
  • Vacuums Master
  • 1,458 Answers
Not knowing your brand and model makes it hard to diagnose. Start by following suction path through your vacuum from the motor to the floor. If you have suction at motor go to next area in the flow from motor to floor. It has to be somewhere in the air flow path
Posted on Dec 04, 2016
Hoover troubleshooting
You will find a blockage in the hose coupling. Check for the high speed sound from the motor, like when it has a blockage and go through the airways until you find it.
Aug 20, 2014 | Vacuums
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
Need to clear a suction blockage
What needs done depends on the vacuum and where the blockage is. You might be able to pull the blockage out or you may have to remove some parts to remove it. Many times a blockage is caused by clogged filters. If the filters do not have adequate airflow it may not be able to moved the debris through the vacuum and causes it to clog. It's important to replace filters at least once per year in most vacuums
Oct 13, 2013 | Vacuums
When the hose is used the cleaner looses suction and the hose contracts. what could be causing this?
There is a blockage in the hose somewhere. Disconnect all of the hose sections (make note of how they all fit back together) and check each one individually for blockages. The straight sections can be done visually by looking through them towards a light source, e.g. a window.
The hose section can also be inspected visually if you compress the stretchy part into a straight line and also look towards a light source. If you can't see light through any section, you have probably found the blockage.
Pay particular attention to the point where the hose enters the vacuum at the back near the bottom. After releasing the hose from this connection, also check inside the fitting that the hose attaches to the hoover.
Once you have found the blockage you will need some kind of rod to remove it. This may be easy or difficult depending on where the blockage is. Basically, you need something about 2 feet long, fairly thin, stiff, straight and - most importantly - blunt ended so it will push the blockage out (rather than pierce through it) and also will not damage the flexible hose. I generally use a section of wooden dowel.
Once you have removed the blockage, reassemble the sections of hose and you should have suction again.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Red light comes on saying bag full or clogged. Bag has only recently been changed so what do I look at next?
You look for a blockage - almost certainly in the flexible hose. Remove the hose from the machine completely (both ends, that is), then switch the machine on and the red light should not come on unless you block the hole on the top of the bag compartment with your hand. Then you need to investigate the hose, to find and remove any blockage. This is not always easy. You can try sucking a blockage out, back the way it came in, either with a second vacuum or simply by reversing it on your Sebo as best you can. This will often pull the blockage to the point where you can get hold of it with pliers or a bent wire or the like. Unless all else fails, and you get desperate, don't try pushing a blockage out with a broom handle or anything like that as you will probably only consolidate the blockage. You should also check in the little trap-door on the underside of the base to make sure all is clear there.
If you need further guidance, just post a reply here and I'll answer as soon as I can. Good luck!
Mar 26, 2010 | Sebo X4 Bagged Upright Vacuum
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Tube to Fantom Thunder canister blocked
I cut a strip of window screen about 1 inch wide and 12 inches long and slid it up the tube from the back of the vacuum. The screen edges grabbed the gunk and as I pulled the screen strip out from the tube the gunk came with it, clearing the blockage.
May 27, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
