Question about Hardware & Accessories
How to set plug in timer switch TE-10 I've lost instructions
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
I lost instructions for setting Woods Outdoor 24-Hour Mechanical Timer. I set time of day and pressed down tabs for on and off time, but nothing happened. What more do I need to do?.
1) Copy following link for how to set analog timer by experimenting with features.
2) Usually you move slide switch to timer, and make sure load is ON and operable before plugging into timer.
Dec 10, 2012 | Woods Outdoor 24 Hour Mechanical Heavy...
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I've got a Heller 10-fin standing oil heater, H-2400T. I would love it if someone can show me where to find the online instruction manual for this. Or just explain how to make the timer function work....
G'Day
I have one of these Heller H-2400T heaters. To operate the timer try this: Plug into power and turn on. Set power control to either Low/Med/High. Set temperature control midway between Low & high.Rotate timer dial to the right to align time of day to the reference point. Ensure all of the red tabs are pulled out. Then push in the ones for the period you want the timer to operate. Works for me. Good luck
Jun 13, 2011 | Heating & Cooling
I lost instructions for Woods TN300. How do I set it?? THANKS and HAPPY NEW YEARS to all and BE SAFE!!!
Woods TN300 and Intermatic TN300 and Woods 59200 are same timer:
To confirm this is your timer, open link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
If this is not your timer, then add a comment for additional free service.
Instructions:
Rotate dial to set current time, when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour. Push segment down like piano key.
Segment pulled up = lights OFF
Segment down = lights ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone to help you solve problems
Jan 01, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Turn lamp ON
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
I JUST NEED THE INSTRUCTIONS ON HOW TO PROGRAMME A B&Q TE106 TIME
I solved this problem myself by Googling B&Q TE103 timer and downloading the B&Q instruction manual for the TE103 which I have printed and also saved to my computer so this does not happen again.
Oct 08, 2009 | Intermatic T104M 208-277Volt 40-amp Timer...
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
Need to set the timmer
You will find a pdf file copy of the instruction manual you are looking for at the following link:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt500cl.ashx
Have a great day!! :)
Apr 22, 2009 | RTO Intermatic DT500CL 10 Amp Indoor...
Hardware & Accessories Logo
187 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
