Question about Refrigerators
Does the welbilt upright freezer suppose to run all the time
I cannot find a temperature control knob on this used model, the freezer works fine but runs all the time?
    Top Expert:
  • Refrigerators Master
  • 48,513 Answers
Nothing is supposed to run all the time . probably low on freon
Posted on Dec 04, 2016
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Jul 31, 2016 | Frigidaire Freezers
Moved, freezer wont run properly, food thawed out, digital readout display flashes E and then flashes #9 alternately. what do I do?
E9 is a defective Temperature Control
  • You will need to replace Part # 297216004 It should be mounted on the evaporator behind the panel in the inside of the freezer.
  • I am including a picture and a link, it should be #21 on the diagram.
  • You have to unscrew the Knob and the 3 screws holding the temperature control Cover and the one holding the probe/sensor (#24 on diagram)
Best of Luck,
JP
http www searspartsdirect com model part FFU14K0DW0 1428 0142000 R0405108...
Jul 08, 2015 | Frigidaire 14.1 cu. ft. Upright Freezer...
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
Wondering if the kenmore 29313 freezer has a way of regulating the temp. can not find a control button or dial please advise Thank you
My Kenmore model 29313 upright freezer's temperature control knob is located at the base, below the door. Check out the left hand side and see if you see the knob there.
Nov 19, 2010 | Refrigerators
It works intermittently. We will go in and things are starting to thaw and the next time it is fine.
most likely this is caused to a failure of the temperature control. next time you notice its not frozen, take a note if it is running or not. if its not, lightly tap on the temp control knob, or try slowly ...does the unit kick on?
its also possible that you have a bad defrost control, but that is less likely
Mar 01, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
