Question about ARC Welding Tools
Can we bypass the arc welding machine broken switch
2 Suggested Answers
  • 37 Answers
SOURCE: My welding machine will not weld?
Hi, put the setting on 150 amps, and see if the welder welds. do you have a gas or electric welder?
some welders have a reset botton in front. tell me how many amps your welder produces.
If this doesn’t work for you please write back. Thanks,
Posted on Nov 23, 2008
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
If I turn the ac dc switch while what dose it do to the wielder. Now im not getting any juice to wield .thank you
Changes between AC and DC voltage at the electrodes.
Q: What Type Of Stick Welder Works Best For All-Around Use?
A: A welder with an AC/DC output, whether its an electric arc machine like Miller\'s Thunderbolt or a gas engine drive like Miller\'s Bobcat.
DC welding offers advantages over AC for most Stick applications, including: easier starts; fewer arc outages and sticking; less spatter/better looking welds; easier vertical up and overhead welding; easier to learn "how to weld" and a smoother arc. DC reverse polarity (electrode positive) provides about 10 percent more penetration at a given amperage than AC, while DC straight polarity (electrode negative) welds thinner metals better.
Q: Does An AC Output Have Any Advantages?
A: Yes, if you need to weld on material that\'s become magnetized from friction, such as when hay, feed or water constantly rub against a steel part. A DC output won\'t work because of "arc blow," where the magnetic field blows the molten filler metal out of the weld puddle. Because an AC output alternates between polarities, it enables you to weld magnetized parts.
Aug 19, 2014 | Computers & Internet
What electronic part is damaged?
Does the electrode stick to the metal? In which case your problem is with the elctrode or your method of striking the arc.
Jul 24, 2013 | Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
My mig welder will not make an arc
There is a small chance the transformer burned out, but more likely the switch has dirty contacts or burned out. If you turn the switch through all heat positions 2 or 3 times before you start welding in the morning, it should remedy it in the future. In the short term, spray some contact cleaner (or even WD 40 in this rare instance) into the heat selector switch and rotate it through the ranges a number of times to remove corrosion from contacts.
Will the wire arc when dragged across the ground clamp? If not- there are internal fuses in the machine and they may be loose or blown. There should be one in series with the "hot side" (the gun) of the circuit and sometimes on the ground clamp side of the circuit.
There is a small chance the transformer burned out, but more likely the switch has severely corroded or dirty contacts or the switch burned out.
Jan 03, 2012 | Welding Tools
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How would i sub-arc welding machine to weld structural iron
sub arc welding is a diffrent process than sheilded metal arc welding
sub arc takes alot of amps and is made for alot of weld in long runs usually set up on a track and is automated
Feb 04, 2010 | Firepower 120 Amp MIG/FLUX Cored Welding...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Puk 111 welding problem
Mine was doing the same, spoke with the technitions and they told me to undo the connector from the hand piece to the machine at the machine, you then need to disassemble this connector and look to see if one of the white wires is dissconnected, if so you need to carefully push the gold plated pin out the back of the connector towards the cable, solder the wire back on and reassemble and it should work.
If not contact the head office and they were very helpfull.
Cheers Robert
May 25, 2009 | Welding Tools
Ground lead arcs when I connect, and auto idle kicks up
Hi
what are you connecting the ground lead to?
Is the welding machine phisicaly in contact to what you are welding ?
Can you electrically insulate the welding machine from everything, say stand it on a sheet of timber?
Regards
Rob
Feb 07, 2009 | Miller Welding Tools
Welding Tools Logo
98 people viewed this question
Top ARC Welding Tools Experts
Craig Butler
Craig Butler
gerald martin
Level 1 Expert
Are you an ARC Welding Tool Expert? Answer questions, earn points and help others
