Question about Miele Washing Machines
Miele washing machine has a main wash light flashing after wash completed
5 Suggested Answers
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
SOURCE: a 12 year old miele
Hi - the problem is the selector switch mechanism behind the front panel as it has very poor clips to hold it in place on the printed circuit board behind it !!! Switch off at mains, remove front panel (3 crosshead screws behind drawer and 3 10mm bolts behind door - should have told you to open door before s/w mains off) - open the small panel at lower left and with a big screwdriver or similar press down spring clip - the door will then open - it may be a bit stiff because of the wiring loom.
Take a digital photograph of the p.c.b. behind the selector and then take all of the cable from the p.c.b. - unscrew abd remove and then you will see the round black plastic approx 50mm diameter and the 3 rather feeble clips holding it - simply press the whole firmly back in the board - and reassemble - hope this is OK for you
Posted on Nov 29, 2010
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Miele w911 washing machine Main Wash light flashing. Replaced carbon brushes. Machine needs kick start or ???
carbon brushes r black as, well, carbon. They need replacing when they r worn not blackened.
try something else
Feb 18, 2015 | Miele Washing Machines
My Miele starts won't wash or drain and the rinses light flashes
switch off main power switch to reset it then,,try to open & close door tightly two three times
Jan 22, 2015 | Miele Washing Machines
Rinse light flashing
There are two main causes for this failure:
- carbon brushes are worn
- electronic is defective
The exact solution is depending on the model of your Miele washing machine and works for all modules that start with:
EDRU, EDSU, EDSTU, EL, ELP, EDPL,
you may visit youfixit.eu for a solution.
Miele repair Address and payment information
Feb 09, 2014 | Miele Washing Machines
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Wash light is blinking
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or blown heating element caused possibly by a blocked pressure chamber.
Jan 08, 2008 | Miele Novotronic W1918A Front Load Washer
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
60 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
