Question about Cameras
Just bought A850v camera and have tried to connect to dvr4-4150 but get no picture,but if i cover the camera the infra-red works so there is power going to it.Any help please
Raj77
  • 27 Answers
SOURCE: power problems
your phone hase battery problem change battery or go to nearest service center
Posted on Sep 13, 2007
SOURCE: Won't power on
and my phone is daed
Posted on May 03, 2008
mellomania
  • 121 Answers
SOURCE: Cannot connect a mobile phone through infra red
try to get a infrared usb device or a cable
Posted on May 24, 2008
IFIXALL
  • 868 Answers
SOURCE: Kitchen Aid Superba ksrg25fkwh05 10-03
Bottom line Steve, I'd place about 97% of my $$$ on the optics board.Change it ,it comes as 2 parts and is a daily issue and is simple to change out. This is the result of Technology making a step in the wrong direction ...........AGAIN !
Steve, I'm Here to Help !
Please Rate This !!! Thank You !!
Posted on Jun 12, 2008
  • 4 Answers
SOURCE: Problem
it isnt the infra red.
on you dvr machine there should be settings or settings on the camera for mirror and flip.
these are features on better cameras and are normally on the camera body, but veiwable on the cctv monitor. they should be menu driven.
I hope this will be of help
Neil
Posted on Jan 19, 2009
Onkyo tx ds777 remote does not working
If battery replacement does not work, your remote control probably has failed.
Dec 20, 2017 | Onkyo Audio Players & Recorders
Tip
Test you remote
Ever wondered if your radio / TV / Receiver / DVD remote is still working? You've changed the batteries and still it does not seem to operate. Test it like this : Using your digital camera or cellphone camera point the infra red LED of the remote into the camera as if to take a picture of the remote like this:
/uploads/howto/2_26_2012_10_23_58_am.jpg
Operate one of the buttons on the remote and watch the remote through the viewer and you should see this:
/uploads/howto/2_26_2012_10_24_55_am.jpg
The LED will be flashing rapidly if the remote is functioning. This is because the infra red signal sent by the LED is not visible to the naked eye but is to the camera's circuitry. Magic!! Now go try it. You know you want to. ;-) ps This will not work on your vehicles remote fob as it works with radio signals and not infra red light.
on Nov 18, 2010 | Televison & Video
Why does my Defender camera, model 26001, not function in color nor does the infra red work?
First check the power supply, make sure you are over 12vdc or 24vac depending on your source with all cameras connected. Try only one camera connected to the power supply. Make sure you have the positive and negative connected correctly. If the power is good the cameras may be bad.
Sep 07, 2014 | Defender Home Security
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
Not responding after changing old battery
Sep 10, 2010 | Samsung TV Remote Control
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
New flatscreen/remote not working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Problem with Wireless infra red spy camera
Dear sir, U have 2 in one corder + cordless IR camera , & ur corder unit is working ur wireless unit is not working .. wireless transmitter is out of order needs repair if any one in ur area is doing this .
Oct 31, 2007 | Sabrent Sbt-Scnv / Color / Mini Wireless...
Problem
Neil
Oct 21, 2007 | Samsung Digimax A50 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
