Which side up do you place paper in upper tray
    Top Expert:
  • Office Equip... Master
  • 41,467 Answers
Depends on what type paper you are using standard makes no difference . photo would use your head
Posted on Dec 03, 2016
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
The screen is reading upper paper jam, but when I open the printer cover, there is no paper that I can see.
Mine did the same thing, so I opened the paper tray and pulled it totally out. Then I moved the adjustable paper holder (inside of the tray, next to the paper) snug toward the paper, to hold the paper in place (lengthwise). That solved it for me! :o)
Jan 26, 2011 | OKI B4300 Led Printer
Paper comes out wrinkled in upper left hand corner. Help?
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 1320 Printer
How do I load paper to print?
Hi mattside92
1) If the paper support flap is open, close it, and then pull the paper tray completely out of the machine. Lift the output paper tray cover.
2) Press and slide the paper side guides (1) and paper length guide (2) to fit the paper size.
3) Fan the stack of paper well to avoid paper jams and misfeeds.
4) Gently put the paper into the paper tray print side down and top edge first. Check that the paper is flat in the tray.
5) Gently adjust the paper side guides with both hands to the paper.
Make sure the paper side guides touch the sides of the paper.
Note
When you use Legal size paper, press
and hold the universal guide release
button as you slide out the front of the
paper tray.
Note
Be careful that you do not push the paper
in too far; it may lift at the back of the tray
and cause feed problems.
6) Close the output paper tray cover.
7) Slowly push the paper tray completely into the machine.
8) While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap
Good Luck, and don't forget to leave a rating
Thanks
Mark
Sep 29, 2009 | Brother MFC-440CN InkJet Printer
Follow instructions in right cover to remove
open the right door right in front of your PCU are 2 long rolls a black and silver turn these by hand so the torn paper between them comes "up" -Carl
Jul 12, 2009 | Ricoh Aficio MP1600SPF Copier
Paper jam at B2
remove the paper tray or all paper trays that you have.
To remove the a tray first you should pull it towards you the most you can than by pulling towards you and in the same time you should lift it up.So again i will explain the procedure, first when is pulled to the max out of the copier you should lift it up for some 45 degrees and than pull it toward you. When you will remove the paper tray or trays inside of the copier where ware the paper tray on the right side of the inside should have some piece of paper which is stuck there. After you will remove the piece of paper the copier should not jammed the paper in B2.
Also see do the paper in the tray is putted as most close to the right fence of the tray, also see do the right green leveler is also closest to the paper in the tray. If the paper on the left and right side of the upper named fences is loosen than the rubber on the right side of the tray will not be able to pull up the paper in the copier when it will need to do it.
Jul 11, 2009 | Ricoh Aficio 2015 Copier
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
k24674
