Question about Health & Beauty
I need a battery cover for v24130 scale - Health & Beauty
    Top Expert:
  • Health & Beauty Master
  • 8,204 Answers
How do I insert batteries into scale
Battery compartment is usually on the underside, and you may need to remove a cover secured by one or more screws.
Mar 17, 2016 | Health & Beauty
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
How do replace the battery on a EverWeigh Lithium Electronic Scale
The battery is located behind the LCD screen, slightly on the right hand side side if you are facing the LCD screen. You can drill a hole on the platic case from the back of the scale, and you will see the battery house and 3 screws on the battery house lid, unscrew the 3 screws, you can take out and replace the 3V Eveready button type battery easily.
I have tried to open the case by taking out the spring latches located behind the 4 legs of the scale, it was much harder to put every thing back afterward.
Yi from San Jose, CA
Dec 03, 2009 | Health-O-Meter Health & Beauty
Replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Conair Health & Beauty
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Battery cover
This link allows you to ask questions and request a users manual....I hope this helps.
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Health & Beauty Logo
118 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
