My sanyo top loading washing machine drain all water after being filled up and thus refuse to undergo the washing process
Jimster
  • 240 Answers
SOURCE: kenmore top load (model # 110 82370120) drain problem
Good AM. I see here that you have a fairly old belt drive Kenmore washer. The real problem with these is that the parts for them are so very expensive anymore to get. A timer (which you may be needing) will run you around $100.00 to $175.00 depending on where you live. Very expensive repairs on these, but if you want to go for it, here are some hints to help. Sounds like you have one of three problems. First off PLEASE UNPLUG YOUR MACHINE BEFORE WORKING ON IT. Your timer may have lost or has a stuck contact inside (unrepairable in most cases) which is making it do something is shouldnt be doing in that area of the timer. This would probably be the most expensive of your repair. The next thing is it could be the water level switch could be going bad. This one is highly doubtful since it fills and stops filling, but I have heard (but never have seen) that they can short out sometimes and cause wacky operation. Both these issues can be fixed by remove the console rear panel and front knobs to remove both. The next item could be a defective wig-wag in the bottom of the unit. One of the positioning solinoids maybe going bad and sending bad signals back to the timer.
None of these problems are really hard to fix. And truthfully (even though some of these guys will be mad) you can sometimes find these parts on ebay for a halfway good price. Part numbers for each are:
Timer: 381860
Water Level Switch: 359712
Wig-Wag: 89814
Good luck with this one, and if you know how to use one, try to run resistance with an ohm-meter on your wig-wag to be sure your getting power flow through the soilnoids (you will have 2, be sure to unplug the solinoids before testing to be sure its a true test) before replacing.
Posted on Dec 06, 2007
gwshaw71
  • 83 Answers
SOURCE: VBXR1090DBWW top load wahsing machine
your problem is your lid switch
Posted on Dec 07, 2007
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
Posted on Oct 02, 2008
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: My maytag washer will fill up with water but not start washing
Replace your lid switch.
Posted on Mar 08, 2009
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
May 15, 2010 | General Electric WHDSR209DWW Top Load...
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Kenmore top load (model # 110 82370120) drain problem
Could you please rephrase the question. I'm not sure if I'm understanding this correctly
Dec 01, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
