Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Red green lines across my screen on 51 inch tv hdtv
It also has a blueish haze to it. the red n green lines are real bright you go into to adjust them n you cant the crosses are not aligned n cant be aligned the are bouncing all up n down
  • 30 Answers
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Posted on Jul 20, 2009
  • liznichols42 Sep 07, 2010
    what does align the crosses mean how do I do that?
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Aug 31, 2009
Green hazy lines across my projection tv screen
The coolant in between the CRT face and the focus lens has probably become discolored and would need to be drained, cleaned and refilled. The green CRT is the center one and it would have to be romoved in order to refill it.
Sep 20, 2009 | Philips 51PW9363 51" Rear Projection...
Red an green lines across the tv about every two
Sounds like you have retrace lines in your picture. It may resemble something like window blinds, but slanted to the lower right. You most likely have a bad crt or the AKB circuit is bad. This most likely needs a technician to adjust the G2's to see if it can be balanced.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Screen has green horizontal lines
could be the transformer due to the price you paid for the tv might be wothwhile having it replaced
Mar 19, 2008 | Philips 51PW9303 51" Rear Projection...
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
488 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
